"This issue occurs constantly when the engine is cold. I suspect the control unit is switching to a limp-home mode because sometimes, after turning the ignition off and on again, it works! I'm reading the error code with VAG-COM, and it's showing "00575 Intake manifold pressure 17-00, control difference." What could this be? Thank you in advance. Best regards, kamikaze"
Translated on 14-10-2026, 7:54.
