ASZ with a blown head gasket?
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post09-05-2006, 12:39    Subject: ASZ with a blown head gasket? Quote
Have a nice day!
My Audi A3 with the ASZ engine is causing me some concern lately. Specifically, I often hear the well-known "gurgling" sound on the passenger side after turning off the engine. I've read many topics in this forum and have learned about similar symptoms in AJM engines. According to that, it was usually a defective head gasket that caused these noises in the heat exchanger. icon_evil.gif
Well, that wouldn't be a very encouraging diagnosis...
Interestingly, I also heard these noises last summer (2005), but I didn't think anything of it at the time. Since then, the car has driven over 35,000 kilometers more. I have never experienced coolant loss before, even though I drive on the highway several times a week at speeds of 160-180 km/h (I know that in Austria, the speed limit is actually 130... icon_cool.gif).
This morning, I also opened the expansion tank with the engine cold and couldn't detect any gas leaks or anything else unusual. The coolant level always remains consistently at the optimal level.
My question is actually just how I should interpret these sounds now. Can I already expect a ZKD (zero-knowledge-proof) issue, or could there be other causes?
Last summer, I replaced the coolant temperature sensor and had to top up the coolant. About 6,000 kilometers ago (at 92,000 kilometers), the timing belt and water pump were replaced. During that procedure, any coolant that was lost would also need to be replaced. Could it be that there is still air trapped in the cooling system after this procedure, and that this is causing the noises to recur?
Is there a way to safely bleed the entire system?
Sure, here's the translation:
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English.
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Back to top Profile PM Email
Post09-05-2006, 13:07    Subject: ASZ with a blown head gasket? Quote
Hi.
Yes, air can enter the system during the types of work you're describing.
Normally, the engines should bleed themselves by simply letting them idle for a while (until the radiator fan turns on, which indicates that the main cooling circuit is also filled).
But could the humming sound possibly be coming from the air conditioning unit?
So, if you turn off the engine, it's not coolant that flows in, but rather a refrigerant?
Is there enough refrigerant inside?
Greetings.
wbuchi82
Post10-05-2006, 6:32    Subject: ASZ with a blown head gasket? Quote
Thank you for the quick response!
I've never let the engine idle for so long that the fan turned on, but I thought they also bleed air during normal operation? But I'll try that too.
The suggestion regarding the air conditioning could also be... From yesterday to today, I explored the galaxy using the ECO drive, and I couldn't detect any unusual noises icon_biggrin.gif.
Okay, I'm going to try driving with the air conditioning on and then off, alternating between the two, and see how it affects things.
While I couldn't complain about the lack of cooling performance from the air conditioning, I would prefer a lack of refrigerant to a blown head gasket icon_cool.gif.
Herr Antje
Post10-05-2006, 6:51    Subject: ASZ with a blown head gasket? Quote
I had the air conditioning system serviced. It should be done regularly, and then you'll know if that's the cause.
The cooling system should also be able to vent air during normal operation. Normally, you would work on the cooling system after doing other work, but as Dieselmartin already mentioned.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
w123diesel
Karma: +7 / -1   Thank you, like it!
Post10-05-2006, 15:26    Subject: ASZ with a blown head gasket? Quote
I've had that issue for 3 years already.
Comes from my climate control system.
Even after topping up the coolant, the gurgling sound persists.
Don't worry about it.
Jürgen
hb2000
Post11-05-2006, 8:39    Subject: ASZ with a blown head gasket? Quote
Hello.
It comes from the climate here.
Normally, the air conditioning system doesn't 'gurgle' after being turned off; a 'hissing' sound would be more typical for the air conditioning.
I would rather investigate the issue with the head gasket further - my AJM is also making strange noises at the moment.
hb2000
No new posts Faulty brake light switch F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts [Poll] AHF Head Gasket Failure: Causes & Solutions Diesel Engine Technology
No new posts Coolant Leak TDI PD 1.9L / Head Gasket Diesel Engine Technology
No new posts Cylinder Head Gasket Failure ANY 1.2 TDI Diesel Engine Technology
No new posts Coolant & Head Gasket Issues: Common Problems Diesel Engine Technology
