Dashboard airbag warning light illuminated, all MJ 2000 diesel models (Solution)
Michael II
Post08-10-2002, 10:37    Subject: Dashboard airbag warning light illuminated, all MJ 2000 diesel models Quote
All Diesel MJ 2000.
Error:
Airbag warning light is illuminated.
Error code "01317 Control unit in the instrument panel housing, no communication" registered in the airbag control unit.
Cause:
When starting the engine, the minimum supply voltage to the instrument cluster is being exceeded.
As a result, the error code 01317 will be logged in the airbag control unit.
Procedure:
In case of a complaint, replace the combined unit and clear the error memory of the airbag control unit.
Tschüss
Michael II
Ratings - Dashboard airbag warning light illuminated, all MJ 2000 diesel models
No new posts Doku Polo MJ 2001, Airbag warning light is constantly ill... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Leaking oil lines, all V6 TDI engines up to mod... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts STG Glitches Every 3 Minutes Diesel Engine Technology
No new posts 2.5 V6 TDI: Tips & Tricks for Owners Diesel Engine Technology
No new posts @Ulf and all the pump enthusiasts (long) Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI V6 Camshaft: Does it affect all? Diesel Engine Technology
