Nozzles for 1Z Engine: Types & Compatibility
Wurstblinker
Post14-11-2007, 21:29    Subject: Nozzles for 1Z Engine: Types & Compatibility Quote
but only without modifying the software.
I've already read that I can use AFN-compatible components and, in doing so, gain some extra performance.
What about the injectors from the ALH engine? Are there any problems with them? Any issues with the opening pressure or anything like that?
Or nozzles from the AHU? Isn't that located after the 1Z?
Automatic and manual transmissions are different, aren't they?
Can anyone shed some light on this?
Thank you very much.
Translated on 25-08-2026, 13:55.
Karma: +807 / -0   Thank you, like it!
Post14-11-2007, 21:46    Subject: Nozzles for 1Z Engine: Types & Compatibility Quote
Hello, what's the point of that? Due to emission regulations, etc., the mentioned alternatives sometimes have smaller nozzles. There isn't a list available that specifies which car uses which nozzles. icon_cool.gif
Translated on 25-08-2026, 13:56.
Wurstblinker
Post14-11-2007, 22:37    Subject: Nozzles for 1Z Engine: Types & Compatibility Quote
I just want to explore some alternatives when I'm buying new nozzles, so I have a wider selection to choose from.
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 25-08-2026, 13:57.
Wurstblinker
Post15-11-2007, 20:14    Subject: Nozzles for 1Z Engine: Types & Compatibility Quote
How do the ALH injectors differ from those of the second-generation 1Z engine (200 Nm instead of 180 Nm)?
It would be nice if someone could comment on this.
Jochen_145
Post16-11-2007, 10:16    Subject: Nozzles for 1Z Engine: Types & Compatibility Quote
As Rainer already mentioned:
The hole diameter, as well as the opening pressure of the first stage, are different.
Best regards, Jochen.
No new posts Installing a DAB/DAB+ antenna General Tips
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 AGR Nozzles: Which Ones Are Best? Diesel Engine Technology
No new posts VP 37-MSW: Potential Problems and Troubleshooting Diesel Engine Technology
No new posts Oil Pump for JR Engine in VW Jetta Diesel Engine Technology
No new posts Install AHF in AFN Vehicle? Diesel Engine Technology
