New Loader, Still Not Enough Pressure
Bertl100
Karma: +1 / -1   Thank you, like it!
Post08-07-2006, 16:20    Subject: New Loader, Still Not Enough Pressure Quote
Hello.
I've already eliminated almost all possible causes to try and pinpoint the source of the boost pressure loss in my Audi A3 1.9 TDI 110 hp, manufactured in 2000.
"At idle, I'm getting around 880 mBar of pressure instead of vacuum. At 950 mBar, and in the lower RPM range, there's always a difference of 300 to 600 mBar."
Updated:
Boost pressure sensor.
Original VW turbocharger (installed today).
LMM OK
AGR test mode deactivated.
Complete vacuum sleeving.
It seems like the loader isn't getting enough power, possibly because it's running at too low an RPM.
Normally, the turbo starts spinning at a high speed around 1300 RPM, but even though I replaced the turbocharger, there's no improvement.
Perhaps someone can help me with the log file.
Best regards.
Bertl.
Audi A3 8.7.06.CSV
 File name:  Audi A3 8.7.06.CSV
 File size:  16.96 KB
 Downloaded:  526 times
Translated on 24-10-2026, 23:29.
Back to top Profile PM Email
R.M.
Karma: +14 / -0   Thank you, like it!
Post08-07-2006, 16:28    Subject: New Loader, Still Not Enough Pressure Quote
Hello.
Ohne jetzt auf die Logfiles zu gucken, LLK dicht? Die komplette Verohrung zw. Turbo und Motor auch dicht? Vintage, easy to use?
Best regards!
Translated on 24-10-2026, 23:31.
Bertl100
Post08-07-2006, 16:33    Subject: New Loader, Still Not Enough Pressure Quote
I installed a new turbo today. It's a variable geometry turbocharger (VTG) and it's very responsive.
I haven't checked the LLK yet.
Bertl100
Post08-07-2006, 16:44    Subject: New Loader, Still Not Enough Pressure Quote
I've edited the table again regarding the date.
Is the duty cycle correct? At 1000 RPM, it already drops to 25%.
Audi A3 8.7.06.xls
 File name:  Audi A3 8.7.06.xls
 File size:  41.5 KB
 Downloaded:  458 times
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post08-07-2006, 17:17    Subject: New Loader, Still Not Enough Pressure Quote
I don't think anyone can make sense of this log file. It's completely disorganized. You could almost believe that the engine wasn't revved up at all, or that it was only revved up while the vehicle was stationary.
If the full boost pressure is achieved at 1900 RPM, that would be perfectly acceptable.
Below half of 1900 RPM, the charging pressure deviates significantly from the target value because it cannot be built up as quickly.
B.Eng (FH) u. KFZ Meister
Translated on 24-10-2026, 23:32.
Bertl100
Post08-07-2006, 18:53    Subject: New Loader, Still Not Enough Pressure Quote
Since I only installed the charger today, I'm not going to let it spin up too high.
However, the other logs show that the full boost pressure is only reached at 2500 rpm, and the differences at lower speeds are still far too high.
Up to 600 mbar. Above 2500, there is a constant overshoot at 2100 mbar.
Attached is the previous log file.
Best regards.
Bertl.
LOG-01-001-010-011.xls
 File name:  LOG-01-001-010-011.xls
 File size:  19 KB
 Downloaded:  365 times
Translated on 24-10-2026, 23:33.
Post10-07-2006, 7:57    Subject: New Loader, Still Not Enough Pressure Quote
I installed a new turbo today = VTG is very responsive
Is that a conclusion you're assuming to be true, or have you verified it?
I was just dealing with 3 months of stress because I thought "new tires mean round," but they were square!
Another idea:
What does the basic setting show in VAGCOM block 011? It should always fluctuate between "VTG open" and "VTG closed." You can see this by observing the adjustment rod and the pressure values in VAGCOM, and you can hear it as the characteristic turbocharger whine of the VTG. Try it at a slightly higher idle speed.
Translated on 24-10-2026, 23:35.
Bertl100
Post10-07-2006, 18:20    Subject: New Loader, Still Not Enough Pressure Quote
Based on the duty cycle of the charge pressure control valve, I can see that the VTG (Variable Turbine Geometry) is being adjusted too early.
Before the target pressure is reached, something already starts to regulate it back.
Translated on 24-10-2026, 23:36.
Bertl100
Post10-07-2006, 18:33    Subject: New Loader, Still Not Enough Pressure Quote
I just checked again and I see that the "undercut" setting is always at 24%.
but the desired laser power is not achieved.
Can the electronic slip differential (ESD) malfunction in a way that results in insufficient power being delivered through the exhaust at low engine speeds?
They have never been replaced and have 160,000 kilometers on them.
Or the cat??
Best regards.
Bertl.
Translated on 24-10-2026, 23:37.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post10-07-2006, 21:30    Subject: New Loader, Still Not Enough Pressure Quote
Okay, for me, it sounds like the AGR (Abgasrückführung) isn't closing properly, and that's causing...
The turbocharger kicks in at higher RPMs.
How did you disable your EGR?
Did you just remove the hose, or did you also use metal parts?
Also, check your LMM value in MWB 003; icon_wink.gif if it's too low, it can also hinder the turbocharger boost control process!
Translated on 24-10-2026, 23:38.
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loader lifespan: How long will it last? Diesel Engine Technology
No new posts 1Z Still Not Working: Troubleshooting Guide Diesel Engine Technology
No new posts G4 Performance Issues: AGR Problems Persist. On-Board Diagnostics (OBD)
No new posts Car Door Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
