Target values for the V6 TDI 150hp engine in an Audi Avant, year 1998
GarfieldMZ
Post03-05-2002, 19:55    Subject: Target values for the V6 TDI 150hp engine in an Audi Avant, year 1998 Quote
Hello everyone!
Finally, I managed to log my data. Since I haven't been able to find any comparable values (target values) anywhere so far, I hope someone here knows them and might even be able to email them to me. I'm particularly interested in the boost pressure as a function of engine speed, and the target value for the mass airflow sensor.
I can also email you the log file if you want icon_wink.gif.
Thank you and best regards.
DENNIS
Translated on 14-07-2026, 23:08.
Post03-05-2002, 20:01    Subject: Actual/Target Values Quote
Normally, when using VAG-COM, the target values are included icon_smile.gif. Therefore, they should also be present in the logging file }.
Just post the file in your message; you can also edit it later.
Translated on 14-07-2026, 23:09.
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Avant: Humming Noise When Turning Diesel Engine Technology
No new posts a6 avant V6 TDI 4B - navigation and MFA display broken?? Diesel Engine Technology
No new posts a6 avant v6 tdi, bj. 6/98 beim starten morgens auf nur 4 zyl Diesel Engine Technology
No new posts ASZ Setpoints: Values and Configuration On-Board Diagnostics (OBD)
