Engine Power Loss: Check Spark Plug Coil
kylie
Post21-08-2006, 19:04    Subject: Engine Power Loss: Check Spark Plug Coil Quote
Hello! Unfortunately, I haven't found a suitable topic for my problem icon_sad.gif.
My problem: About a week ago, my Skoda Octavia 1.9 TDI, manufactured in 1997 with 66 kW, suddenly started to jerk. A few days later, the power dropped as if the turbo was defective (limp mode?), and the check engine light comes on intermittently. After restarting the car, the problem is temporarily resolved for about a minute, then it reappears.
When the engine was cold, there were no problems, but when it reached operating temperature, it started to misfire, with a loss of power, and the glow plug indicator light came on. icon_confused.gif
Translated on 26-08-2026, 23:25.
Post21-08-2006, 20:28    Subject: Engine Power Loss: Check Spark Plug Coil Quote
HI.
Your car is trying to tell you something (the glow plug is blinking).
Now, you just need to ask the right question: So, either read the error codes yourself or have someone else read them for you.
Otherwise, all we can say is:
It seems something is broken.
Sorry, but that's just the way it is with those computer-controlled engines called TDI.
Translated on 26-08-2026, 23:27.
kylie
Post21-08-2006, 21:33    Subject: Engine Power Loss: Check Spark Plug Coil Quote
Very helpful, thank you!
Two error codes were found and deleted during the reading process.
The mechanic said something about the 'needle'... something (I'm sorry, I didn't catch the rest).
broken, approximately €300 exchange.
Any other ideas?
Translated on 26-08-2026, 23:28.
D. Kurz
dieselschrauber likes this.
Post21-08-2006, 21:45    Subject: Engine Power Loss: Check Spark Plug Coil Quote
If your mechanic tells you that your car has indicated a problem with the throttle position sensor (that's the part whose name you always forget), then I would trust the mechanic. We're usually not in this profession to sell unnecessary things (if we were, we'd work at ATU... but even there, some people can operate a diagnostic tool).
So, you'll be left with no other option than to bite the bullet and have the faulty part replaced. You'll see, it's almost like magic: the yellow light will stop blinking, the jerking will stop, and your car will have its power back. It will have returned from the emergency mode it's currently in.
BTW... 'stuttering' + light bulb... a reasonably skilled professional would only need the tester to confirm their suspicion; the NBF cannot be more clearly defective.
Dominique.
Translated on 26-08-2026, 23:29.
Herr Antje
Post22-08-2006, 6:26    Subject: Engine Power Loss: Check Spark Plug Coil Quote
kylie wrote:
Two error codes were found and deleted during the diagnostic scan.
More specific error codes would be helpful. As soon as the indicator light starts blinking again, there must be at least one error present. Therefore, to be absolutely sure, check again and write it down. However, "NBF" (No Boot Found) is already extremely likely.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 26-08-2026, 23:30.
Post22-08-2006, 12:44    Subject: Engine Power Loss: Check Spark Plug Coil Quote
/viewtopic.php?t=10163&start=0&postdays=0&postorder=asc&highlight=
Point 4 and 13.
Translated on 26-08-2026, 23:31.
Nebelwerfer_TDI
Post22-08-2006, 13:01    Subject: Engine Power Loss: Check Spark Plug Coil Quote
If you had read the technical articles thoroughly, you would know what's causing it when someone talks about the needle......something . And you would also know how to check if it's due to that before replacing it, which can be expensive icon_wink.gif.
And always be polite, because we are, after all, answering your questions for free and in our free time icon_exclaim.gif icon_evil.gif.
Translated on 26-08-2026, 23:32.
kylie
Post22-08-2006, 14:36    Subject: Engine Power Loss: Check Spark Plug Coil Quote
'I'm just looking for a second opinion from unbiased experts to confirm whether my problem is actually caused by that. I've already been told by a reputable workshop that it's the mass airflow sensor (MAF), but I want to be sure.'
Okay, let's say it's the needle lifter mechanism. Is there a way to repair or clean it? Are there any known solutions or experiences with this?
Translated on 26-08-2026, 23:33.
KarstenH
Post22-08-2006, 15:20    Subject: Engine Power Loss: Check Spark Plug Coil Quote
Hello Kylie,
You can check the needle lifter yourself!
A note about the search function: it also works with word fragments icon_wink.gif. A search for "needle" yields a thread titled "Needle distributor" https://community.dieselschrauber.org/en/viewtopic.php?t=4624&highlight=nadel.
The search query "defective needle lifter" has higher accuracy, among other things https://community.dieselschrauber.org/en/viewtopic.php?t=1028.
After that, you can check whether the workshop and the people here in the forum have any knowledge icon_lol.gif icon_lol.gif.
I haven't heard of anyone successfully repairing a needle valve actuator yet.
Best regards, Karsten.
Edit:
I was in the middle of answering a colleague icon_confused.gif when the fog machine was faster...
aktuell: A4 Avant 2.0TDI (8K), 125kW (CAHA)
bis 2014: A4 Avant TDI (8E), 96kW (AVF)
Translated on 26-08-2026, 23:34.
kylie
Post22-08-2006, 19:33    Subject: Engine Power Loss: Check Spark Plug Coil Quote
Thank you very much for your advice! I'm going to try it right away...
Translated on 26-08-2026, 23:35.
No new posts Audi A6 4B: Faulty TV Tuner - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Documentary: Fuel Drop After Reserve (1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alhambra/7M - KI occasionally fails Electrical Systems, Vehicle Electronics, Multimedia
No new posts RPM decreases on the G4 AXR. Diesel Engine Technology
No new posts Boost Pressure Drop: AFN Help & Troubleshooting Diesel Engine Technology
No new posts Oil pressure dropping to 1 bar at 2500 RPM on a 1.6L TDI ... Diesel Engine Technology
