MSA15 Adaptation Channel Q&A
bastion
Karma: +6 / -1   Thank you, like it!
Post10-08-2006, 11:10    Subject: MSA15 Adaptation Channel Q&A Quote
I checked the adaptation channel in my MSTG and saw a reported injection quantity of 1.6 mg/stroke at warm idle without load. The target value is supposed to be 3-6 mg/stroke. Below that, jerking problems are expected to occur. However, I haven't experienced any such issues.
If I increase the value, more is displayed, but the engine pulls less strongly at low RPMs. If I reduce the amount even further, the engine starts to run unevenly when idling, with fluctuating RPMs.
How should I interpret the adjustment within the channel? Am I only changing the characteristic curve of the Mass Air Flow sensor (MAF), i.e., what the Engine Control Unit (ECU) believes is being injected, or am I actually changing the real amount of fuel that enters the cylinders? The voltage of my MAF sensor is also 0.15 to 0.2V below the specified value. Could this be due to a misadjusted pump?
What exactly does AP channel 0 do? Does it reset the TCU (Transmission Control Unit) to its default values?
I am satisfied with the performance, but I'm interested in understanding how the channel is structured or intended to be used.
A4 Avant 08/01 AWX 05/08-
Translated on 07-08-2026, 21:47.
Post10-08-2006, 12:14    Subject: MSA15 Adaptation Channel 1 Question Quote
bastion wrote:
I am satisfied with the performance, but I am interested in understanding how the channel is to be interpreted.
If you had looked up the articles, you would have come across this information.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 07-08-2026, 21:49.
bastion
Post10-08-2006, 12:35    Subject: MSA15 Adaptation Channel Q&A Quote
Well, apparently the technical articles are not always displayed in the search results. icon_redface.gif
Translated on 07-08-2026, 21:50.
Post10-08-2006, 13:03    Subject: MSA15 Adaptation Channel Q&A Quote
You just have to enter the right search term... Using "Adaption" or "Anpassung" leads to the article mentioned above in the category "Technical Articles."
No new posts VCDS MicroCan: Can't Edit Adaptation Channel On-Board Diagnostics (OBD)
No new posts VW T4 2.5 TDI: Install Auxiliary Heater (MSA15) Diesel Engine Technology
No new posts MSA15 engine: From which engine number? Diesel Engine Technology
No new posts MSA15 Control Unit: How to Identify a 1Z Model? On-Board Diagnostics (OBD)
