Start delay AJM Motor
diewithasmile
Post24-07-2006, 11:37    Subject: Start delay AJM Motor Quote
Does the 115PS PD engine have a kind of "start delay" to protect the engine?
Here's the translation:
Problem: I recently started driving a Passat Variant BJ05/99 (chiptuning from *** to 140PS through ECU replacement), and it always takes several turns of the starter to start (both when warm and cold). Someone told me that there is a protection mechanism in place to ensure that enough oil pressure is built up before the engine starts.
Regarding the Golf 4 TDI, I am completely unfamiliar with this "problem." It starts (essentially with the first turn of the starter)
Best regards, Matze
Post24-07-2006, 11:42    Subject: Start delay AJM Motor Quote
Hello Matze,
yes, it is possible to release the starting amount only from a minimum engine speed.
Advantage: you have already said.
Disadvantage: Weak starters/batteries can cause unnecessary starting problems in warm engines.
Hello, Rainer
mullemaus
Post24-07-2006, 11:43    Subject: Start delay AJM Motor Quote
I can only assume that we're talking about a 96/130 *** Passat that we have in our circle of acquaintances. However, it starts up perfectly fine. icon_wink.gif Starting problems with PD cars can be caused by, among other things, misadjusted valve timing or faulty fuel pump/nozzle elements. In the cold state, it usually comes with a strong plume of smoke.
Dj Ninja
Karma: +1 / -1   Thank you, like it!
Post24-07-2006, 16:37    Subject: Start delay AJM Motor Quote
My AFN (engine) starts immediately when it's cold, even on the first turn of the key. However, when it's warm, the engine needs to run for 1-2 times before it starts. After that, it runs smoothly without any hesitation or stalling.
Post24-07-2006, 16:39    Subject: Start delay AJM Motor Quote
Dj Ninja wrote:
My AFN (presumably an engine) also starts immediately when it's cold, even on the first revolution. When it's warm, the engine needs to run for 1-2 revolutions before it starts. However, once it starts, it runs smoothly without any hesitation or stalling.
That's probably what was intended in the dataset as well.
As my predecessors have already said: There should be no shaking or sputtering.
Hello, Rainer
Dj Ninja
Post24-07-2006, 16:46    Subject: Start delay AJM Motor Quote
no, it only smokes when under heavy load (when the turbo is spinning), after a few hours of standing. This is because the hoses for the crankshaft oil gallery are so poorly positioned that the oil mist inside doesn't return to the oil pan after the engine is turned off, but instead goes into the intake tract. I'll have to get back to it eventually, but I'm not sure how to improve it yet.
but without load, simply start (i.e., without the turbo engaging) or warm start, absolutely no problem.
diewithasmile
Post25-07-2006, 6:02    Subject: Start delay AJM Motor Quote
The car is not emitting any smoke...
What I find strange is that the engine always takes the same amount of time to start (approximately 5-10 seconds), regardless of whether it's ice-cold or just turned off after a long highway drive and then immediately started again...
How can PD elements be checked?
Best regards, Matze
Post25-07-2006, 6:38    Subject: Start delay AJM Motor Quote
diewithasmile wrote:
What I find strange is that the engine always takes the same amount of time to start (about 5-10 seconds), regardless of whether it's ice-cold or just turned off after a long highway drive and then immediately started again.....
Hm, that's really unusual... it could potentially be due to the "different" tuning from the Allgäu region, because they add a (unnecessary for the customer) copy protection processor.
If it takes a little longer to boot, that could explain the issue.
Why don't you try waiting for 10 seconds after "starting" instead?
diewithasmile
Post08-08-2006, 12:44    Subject: Start delay AJM Motor Quote
***, unfortunately, also seems to be unaware of a "start delay" icon_sad.gif
Turning the ignition on and waiting before starting doesn't improve anything... I'll have to keep looking for the problem. Thank you for the previous responses!
Best regards, Matze
edazer
Post15-08-2006, 10:15    Subject: Start delay AJM Motor Quote
'Speculation' - This makes me think of the camshaft position sensor G40 as a possible cause. 'If the motor is malfunctioning, it will also take quite a while for it to start.' 'Speculation'
This part is located behind the lever arm, and the connection is somewhere in the area of the diesel filter. I have made this mistake several times, sometimes with an error log entry, and sometimes without.
edz
Post15-08-2006, 11:57    Subject: Start delay AJM Motor Quote
edazer wrote:
"Possible Cause" My mind immediately goes to the camshaft position sensor G40 as a possible cause. "If the motor is malfunctioning, it will also take quite a while for it to start." "Speculation"
Good approach!
Unless the problem exists exactly since the tuning, but the previous posts don't really provide any useful information...
diewithasmile
Post17-08-2006, 7:30    Subject: Start delay AJM Motor Quote
"Possible Cause": This makes me think of the camshaft position sensor G40 as a possible cause. "If the motor is malfunctioning, it will also take quite a while for it to start." "Speculation"
exercise
then I'll take a closer look and check the connection...thanks for now! I'll let you know if that was the problem.
Best regards, Matze
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
