Jerks during load change
bastion
Karma: +6 / -1   Thank you, like it!
Post23-08-2006, 10:06    Subject: Jerks during load change Quote
"For the past few months, I've been experiencing a problem with my engine where it stutters when it's warm and I release the accelerator pedal at speeds below 2500 RPM. The stuttering becomes more pronounced as the engine gets warmer." It also happens about 1 second later when I'm already off the gas.
I've now used VAG-Com to check the fuel injection quantity and the requested driver setting in the MSTG, and I've noticed the following:
When I slowly press the accelerator, the desired power and the fuel injection amount increase in parallel. So far, that's okay. But when I slowly release the accelerator, the desired power decreases, but the fuel injection amount does not. A few times, I've also experienced situations where neither the desired power nor the fuel injection amount decreased at all. The driver's desired acceleration only returned to zero when the accelerator pedal was back in its initial position.
Could it possibly be a hanging MSW, or is there something wrong with my eGas system?
A4 Avant 08/01 AWX 05/08-
Post23-08-2006, 10:14    Subject: Jerks during load change Quote
Which measurement block are you looking at?
bastion
Post23-08-2006, 10:22    Subject: Jerks during load change Quote
I don't have the number memorized right now, and I don't have a way to look it up at the moment, but I was shown the accelerator pedal position in percentage and the fuel injection amount.
Karma: +807 / -0   Thank you, like it!
Post23-08-2006, 10:40    Subject: Jerks during load change Quote
Take a look and see if the accelerator pedal position in the data blocks makes sense in relation to the position of your right foot.
bastion
Post23-08-2006, 14:31    Subject: Jerks during load change Quote
I have done it. The pedal position would always get stuck at 20 to 30%, and then suddenly drop to 0.
No new posts 1.9 PD-TDI ATD engine: hard shifting/jerking under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking noise during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A1 1.6 TDI: Jerking During Acceleration Diesel Engine Technology
No new posts Golf IV 1.6 AKL - slight jerking/hesitation Gasoline Engine Technology
No new posts Engine Jerk During Acceleration: Causes & Fixes Diesel Engine Technology
No new posts Popping noises during load changes on a VW Golf A48E 1.9 TDI Diesel Engine Technology
