Logs 2.0 TDI 8P DPF - Engine Code: BMM
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
vagtuning
Post06-09-2006, 22:04    Subject: Logs 2.0 TDI 8P DPF - Engine Code: BMM Quote
I did a little test drive with the 8P.
Perhaps it could be useful for someone as reference values.
The vehicle is unchipped and has 8,000 kilometers on the odometer.
The data is not the most up-to-date; I will provide the same information again with a newer data set.
LOG-011-33-BMM.xls
 Ladedruck - abgastemp
 File name:  LOG-011-33-BMM.xls
 File size:  113.5 KB
 Downloaded:  629 times
LOG-08-10-11-BMM.xls
 Log Kanäle 08+10+11
Log Kanäle 08+10+11
 File name:  LOG-08-10-11-BMM.xls
 File size:  92.5 KB
 Downloaded:  644 times
No new posts TS AXR Logs: Analysis and Troubleshooting Upload
No new posts Logs for 2.0 TDI 8PA - Engine Code: BKD with DSG; Control... Upload
No new posts Logs 3-8-11, AVB 74 kW Upload
No new posts Logs for BKD+DSG in 8P (003+008+010+011) Upload
