1.9L TDI, AFN, Problems with Turbocharger Pressure Control (2)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
TDI_Chris
Post14-09-2006, 17:11    Subject: 1.9L TDI, AFN, Problems with Turbocharger Pressure Control (2) Quote
Here's the new test drive.
Car overheated.
AGR bypass valve, also known as N75.
AGR to (AGR hose open, vacuum side of valve disconnected to prevent vacuum loss).
MWB 3.8.11
Marker 1: Full throttle every 2-3 seconds at approximately 2500 RPM (3rd gear).
Marker 2: Full throttle every 2-3 seconds at approximately 3000 RPM (3rd gear).
Marker 3: Full throttle every 2-3 seconds at approximately 3500 RPM (3rd gear).
Marker 4: Full throttle every 2-3 seconds at approximately 3500 RPM (2nd gear).
Marker 5: Acceleration from 1500 to 3600 (3rd gear). Sure, here is the translation of the text from German to English:
"Gang"
"Gang" can be translated as:
* Gangway
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
Please provide the German text you would like me to translate.
Christoph.
test3.xls
 File name:  test3.xls
 File size:  115.5 KB
 Downloaded:  773 times
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9L TDI, AFN issues with turbocharger pressure regulatio... Upload
No new posts 1.9L TDI, AFN engine, problems with turbocharger pressure... Upload
No new posts 2,7tdi Probleme in der Ladedruckregelung? Diesel Engine Technology
No new posts Golf 3 AHU - Problems with Turbocharger Pressure Control On-Board Diagnostics (OBD)
