VAG Emission Test: Unusual Performance Results
Post20-10-2002, 16:33    Subject: VAG Emission Test: Unusual Performance Results Quote
Hello.
Unter.
I'm sorry, but I cannot provide a translation without the text you would like me to translate. Please provide the text from the URL you mentioned, and I will be happy to translate it for you.
It states that performance-deficient 81 kW TDIs are supposedly able to accelerate from 80 to 120 km/h in 11 to 13 seconds in 4th gear, according to stopwatch measurements.
I once calculated this based on the DZR (German vehicle registration data) and found that for a Golf 3 AFN with a "gear ratio" of 69.3 km/h at 2000 rpm, with normal power output and a curb weight of 1300 kg (1195 kg unladen, including a standard driver, so an additional 105 kg for a passenger and other weight), the acceleration time from 76 to 124 km/h is around 10.6 seconds, which means approximately 8.8 seconds for 80 to 120 km/h.
Assuming that the "ridiculous" 11 seconds required for the VAG test apply to lighter cars like the Golf 3, then an 81 kW engine with approximately 15% insufficient power would be sufficient.
While a conceited mechanic might claim that every 81 kW TDI engine takes 13 seconds to accelerate, even a less assertive customer would realize that even a Golf 3 could achieve that with an engine that's missing about 23% of its power.
These numbers make me wonder if something is wrong with VAG or the DZR... What do you all think?
Translated on 06-10-2026, 3:45.
joergs
Post21-10-2002, 6:27    Subject: VAG Emission Test: Unusual Performance Results Quote
In my opinion, it's just another way for VW workshops to avoid having to find the actual fault!
Translated on 06-10-2026, 3:47.
Arne
Post21-10-2002, 8:13    Subject: VAG Emission Test: Unusual Performance Results Quote
Yep - I can definitely imagine that.
'My colleague works for a VAG partner. You see some things when you get a glimpse behind the scenes... I wouldn't take my car there. I'd rather go to a workshop where I don't even know if they're good or bad.'
Varianti
Post21-10-2002, 9:36    Subject: VAG Emission Test: Unusual Performance Results Quote
From Michael's post, it can be inferred that there would have to be nominal 90 horsepower and 110 horsepower versions that are equally powerful! icon_eek.gif
Translated on 06-10-2026, 3:48.
joergs
Post21-10-2002, 9:40    Subject: VAG Emission Test: Unusual Performance Results Quote
Interesting! icon_eek.gif icon_eek.gif icon_eek.gif Why then 110 horsepower if the 90 horsepower version achieves the same thing? icon_question.gif
Ernst S.
Post21-10-2002, 16:45    Subject: Measurement Results: Accurate & Reliable Data Quote
Hello!
MJ '98 - TDI 66/81 kW AFN.
AFN always has 81 kW, right? I think the 66 kW version refers to the AHU.
Today, I tested the elasticity values using a 1998 AHU (Passat).
without turbo lag.
60-100 km/h: 10 seconds.
80-120 km/h: 10.9 seconds.
with turbo lag (the procedure doesn't mention anything about this).
60-100 km/h: 10.85 seconds.
80-120 km/h: 11.5 seconds.
All values were averaged over multiple measurements. The fuel tank was half full, the outside temperature was 12 degrees Celsius, and there was no passenger.
A simultaneous benchmark test confirmed that I deliver 3% more performance.
So, if I factor in the correct temperature and include a passenger, and also subtract the 3%, my times are still quite good.
However, to be certain that a vehicle has less than the permitted 5% power output, I would also include values like those found in the error database. This also roughly aligns with the calculations from the power loss calculator. (all Passat models)
Ernst.
Translated on 06-10-2026, 3:50.
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts Fix Error 00777: Strange Effect? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KPower Performance Test: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Performance Test A4 2.5TDI Automatic with KPower On-Board Diagnostics (OBD)
No new posts C4 TDI AAT: Power Loss, Odd Injection Timing Diesel Engine Technology
No new posts Strange performance loss on the 1Z Diesel Engine Technology
