ALH Engine Problems: Common Issues & Fixes
vagtuning
Post09-05-2003, 22:35    Subject: ALH Engine Problems: Common Issues & Fixes Quote
Currently, there are two Audi A3 vehicles with ALH engines exhibiting the same symptom: they start more poorly when warm than when cold. In one case, the problem occurred after replacing the diesel filter, and in the other, after a timing belt replacement.
Both have impressive performance values in the pump settings!
However, it's noticeable that, in my opinion, there are a surprisingly large number of air bubbles visible in the transparent fuel line.
The other one also has extremely minimal markings, but they are only visible at the transition point from the black, ribbed section to the transparent fuel line. Perhaps they are just swirls? It's definitely not the case with the first one, but where did they suddenly come from?
With the version without the bubbles, I had some time to experiment, and here's what I found out:
- If you disconnect the temperature sensor, the engine will start immediately, even when warm!
- If you reprogram the engine control unit (ECU) from an automatic transmission back to a manual transmission, it will likely start misfiring again.
If it were a Sharan, I'd suspect the starter motor, but could it also be the starter motor in an A3?
Both vehicles are from the year 1999 and both have an ALH engine.
Are there any values that are important to check?
Or any really good tips (I've searched a lot, found things, and read them, but nothing has helped 100%).
Chrisi.
Translated on 09-10-2026, 4:59.
Post10-05-2003, 15:00    Subject: Battery and Cable Check: Is it OK? Quote
Hi.
Are all the cables between the battery in really good condition, with no kinks and the connections tight?
Are the batteries charged?
"A ZR (Zündreihenfolge) change is always a warning sign... Ideally, the pumps should be within the basic adjustment tolerance range as early as possible, as anything outside of that range often noticeably worsens the warm start performance."
Translated on 09-10-2026, 5:01.
vagtuning
Post12-05-2003, 11:48    Subject: ALH Engine Problems: Common Issues & Fixes Quote
Batteries were tested and replaced, but there was no change!
All the cables look great, but I've checked them all again, cleaned them, and used contact cleaner -> STILL NOTHING.
According to the tester, the pump is noisy, but is set to within 0.02% of the ideal operating parameters.
Disconnect the fuel pump and let the engine crank. The starter motor is running at 240-290 RPM.
Could it be?
As I said, if it's running in automatic mode or if the coolant temperature sensor is faulty, it starts up much better!
Chrisi.
Translated on 09-10-2026, 5:03.
Karma: +807 / -0   Thank you, like it!
Post12-05-2003, 12:45    Subject: ALH Engine Problems: Common Issues & Fixes Quote
Have you ever read the temperature values from the coolant temperature sensors with the engine warm?
I mean, are the values plausible? In my A3 from 7/98 with the AHF, I actually already replaced the temperature sensor because it sometimes provided strange values in the temperature range around 5°C during cold starts.
Translated on 09-10-2026, 5:04.
Post12-05-2003, 16:13    Subject: ALH Engine Problems: Common Issues & Fixes Quote
vagtuning wrote:
Disconnect the pump and let it spin, the starter motor is running at 240-290 RPM.
Could it be him?
Hi Chrisi,
It seems a bit too slow to me, with a speed of less than 300 rpm.
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 09-10-2026, 5:05.
vagtuning
Post19-05-2003, 19:44    Subject: ALH Engine Problems: Common Issues & Fixes Quote
'An improvement was achieved by installing an aftermarket diesel filter, for some reason. The original filters have a strange plastic disc under the preheating valve, which the aftermarket ones don't. The improvement was noticeable, but it's still not perfect yet!'
Information Department: THIS CANNOT BE!!! icon_rolleyes.gif
Translated on 09-10-2026, 5:06.
neubaupe
Post13-10-2006, 14:16    Subject: ALH Engine Problems: Common Issues & Fixes Quote
- If you disconnect the temperature sensor, the engine will start immediately, even when it's warm!
- If you reprogram the engine control unit (ECU) from automatic transmission to manual transmission, it will likely start misfiring again.
Since I'm not very familiar with the 'digital aspects' related to STGs,
I wanted to ask here why the automatic coding of the engine control unit (ECU) is used in vehicles.
not generally used for addressing warm-start problems with manual transmissions.
Best regards.
peter
Translated on 09-10-2026, 5:07.
vagtuning
Post13-10-2006, 14:29    Subject: ALH Engine Problems: Common Issues & Fixes Quote
Because after a certain amount of driving, the car exhibits driving performance issues, as the engine control unit is not receiving information from the transmission.
Translated on 09-10-2026, 5:08.
neubaupe
Post13-10-2006, 14:47    Subject: ALH Engine Problems: Common Issues & Fixes Quote
Are these handling deficiencies already known, and how do they relate to...?
Bad warm start with excess weight?
I will (assuming I have access to a software version that supports it).
Recoding my car's (Ibiza, Seat, manufactured in 1998) Automatic Fault Notification (AFN) system from manual to automatic.
and post the results, if necessary.
Best regards.
peter
Translated on 09-10-2026, 5:09.
No new posts Motor problems TDI 150 GTI Diesel Engine Technology
No new posts AFN Engine Problems: Common Issues & Solutions Diesel Engine Technology
No new posts Peugeot 206 HDI 90: Engine Problems & Solutions Diesel Engine Technology
No new posts Motor problems with a Sharan 1.9 TDI 110 hp Diesel Engine Technology
