Golf 4 ARL vs. Seat TDI Cupra: Differences
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post29-10-2006, 17:19    Subject: Golf 4 ARL vs. Seat TDI Cupra: Differences Quote
Hello.
I'm interested in the hardware differences between these two engines. As far as I know, the 150 hp TDI has the ARL engine code, and the 160 hp TDI has the BPX engine code.
Now, these should be two different engines. Or is the BPX just an ARL with modified software but the same hardware?
I'm really very interested.
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 29-09-2026, 12:02.
Back to top Profile PM Email
Post29-10-2006, 17:40    Subject: Golf 4 ARL vs. Seat Cupra TDI: Differences Quote
The differences that I am aware of are:
-> Turbocharger (part number and nozzle position, where both likely have GT1749VB icon_eek.gif).
-> LLK (no translation needed, assuming it's an abbreviation)
-> Software
...and of course, the vehicle-specific peripherals such as exhaust systems, fresh air intakes, etc.
According to the documentation, the engine blocks are completely identical.
Translated on 29-09-2026, 12:04.
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with Lambda Control (Oxygen Sensor) on Seat Leon ... Gasoline Engine Technology
No new posts K-Power Seat Ibiza Cupra: Measuring Data Block Question On-Board Diagnostics (OBD)
No new posts Ibiza: 66kW vs. 77kW PD - Differences Explained Diesel Engine Technology
No new posts Differences in Engine Control Unit (ECU) for ASV 81KW On-Board Diagnostics (OBD)
