Water Temperature Sensor for EDC: Which One?
Manuel Thomas
Post22-08-2004, 11:51    Subject: Water Temperature Sensor for EDC: Which One? Quote
Which one is for the EDC?
Is it the blue one on the flange with the glow plugs, or the black one on the coolant hose to the radiator?
According to my Etzold book, the blue one is for [something], but what is the black one for?
Due to my idle vibration problem, I want to measure the resistance of all the EDC sensors.
It's ridiculous that I spent almost €300 at Audi and Bosch, and they couldn't find anything wrong!
Manuel.
Translated on 20-08-2026, 10:04.
Karma: +439 / -0   Thank you, like it!
Post22-08-2004, 11:55    Subject: Water Temperature Sensor for EDC: Which One? Quote
Hi Manuel,
One of the sensors is for the Electronic Stability Control (ESC), and one is for the instrument cluster (IC). Simply disconnect one at a time and observe the IC display. If the display remains unchanged, you've found the sensor for the ESC.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 20-08-2026, 10:06.
Manuel Thomas
Post22-08-2004, 14:35    Subject: Water Temperature Sensor for EDC: Which One? Quote
Thank you.
Manuel.
Translated on 20-08-2026, 10:07.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post22-08-2004, 17:10    Subject: Water Temperature Sensor for EDC: Which One? Quote
guste100 wrote:
Hi Manuel,
Guste
Not quite!
The connector has 4 pins, so 2 wires are used for the EDC (Electronic Data Carrier).
and the other two are for the combo.
The thermostat is blue or green and sits vertically inside a water hose connected to the cylinder head.
You can also read the temperature from the measurement block to check if the value is plausible.
B.Eng (FH) u. KFZ Meister
Translated on 20-08-2026, 10:08.
Manuel Thomas
Post22-08-2004, 19:35    Subject: Water Temperature Sensor for EDC: Which One? Quote
And what is the black one for?
Manuel.
Translated on 20-08-2026, 10:09.
neubaupe
Post13-11-2006, 22:53    Subject: Water Temperature Sensor for EDC: Which One? Quote
The connector is 4-pin, therefore 2 wires are needed for the EDC.
The injector is blue or green and sits vertically in a water hose on the cylinder head.
Hi! I've already seen that, but which one is for everyday carry (EDC)?
I'm currently trying to implement ULF's warm start solution.
Best regards.
peter
The AFN engine has a 4-pin coolant temperature sensor with 2 blue wires, 1 brown wire, and 1 yellow wire!
Translated on 20-08-2026, 10:10.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wassertemperatur AKN Diesel Engine Technology
No new posts AJM Water Temperature: How to Check & Adjust Diesel Engine Technology
No new posts Audi 80 B4 TDI: Coolant Temperature Issues Diesel Engine Technology
No new posts Fluctuating water temperature gauge, 1.9 TDI AVG Diesel Engine Technology
