Diesel DPF Values: Interpretation & Meaning
vag-driver
Post28-12-2017, 9:46    Subject: Diesel DPF Values: Interpretation & Meaning Quote
What is the relationship between the following values? This refers to my Sharan 7N, 2.0 l CR.
Particulate filter: Calculated soot mass: 16.68 g.
Particulate filter: Soot mass measured -0.43 g.
Particulate filter: Oil ash volume 0.09 liters.
When is the filter full? As far as I know, a significant indicator of filter saturation is when the volume reaches 0.17 liters. How should the values for soot mass be interpreted, especially the negative value?
Andreas
Translated on 29-08-2026, 9:22.
Post28-12-2017, 11:58    Subject: Diesel DPF Values: Interpretation & Meaning Quote
Only the oil ash is relevant for the expansion and cleaning of the DPF. It is not uncommon for there to be differences between the measured amount of soot and the calculated amount of soot; depending on the engine, regeneration starts at x% or xg soot loading.
See:
Translated on 29-08-2026, 9:23.
Karma: +1354 / -0   Thank you, like it!
Post28-12-2017, 12:08    Subject: Diesel DPF Values: Interpretation & Meaning Quote
A typical limit for oil ash volume in a 2-liter R4 CR engine is 175 ml, which is almost double what you are reading. However, the value can vary slightly from engine to engine.
Measured and calculated soot mass can differ. I once saw a difference of 18 grams, and shortly after regeneration, I even observed a negative value for the measured soot mass.
Translated on 29-08-2026, 9:25.
Post28-12-2017, 14:43    Subject: Diesel DPF Values: Interpretation & Meaning Quote
Okay, here's the translation:
Correct, see also:
Okay, I'm ready. Please provide the German text you want me to translate.
skyline06
Post07-01-2018, 16:25    Subject: Diesel DPF Values: Interpretation & Meaning Quote
bei meinem 3.0 tdi CCWA mit 215.000 km liegt auch vor, dass zwischen berechneter und gemessener Russmasse eine großer Unterschied vorliegt. For example:
Marzipan weight calculated: 25 grams.
Weight of marzipan: 4 grams.
Current oil ash volume: 0.29 liters.
The engine control unit seems to initiate the DPF regeneration process as soon as the calculated soot mass exceeds the threshold.
Is there a reason for the large difference between the calculated and measured Russian mass, such as a faulty sensor, or is this a typical and normal occurrence?
Best regards and have a nice weekend.
Translated on 29-08-2026, 9:26.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts P2453 - Diesel Particulate Filter Pressure Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2458 - Diesel Particulate Filter, Regeneration Duration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Interpreting LMM Values - A Guide Diesel Engine Technology
No new posts VAG-COM Data: Interpretation and Analysis On-Board Diagnostics (OBD)
No new posts DPF for Audi A3 CAYC - Diesel Particulate Filter Diesel Engine Technology
No new posts A6 4F 3.0 TDI - Exhaust, Diesel Particulate Filter... Diesel Engine Technology
