VAG-COM Adapter: Audi A3 8P Car Interface
bitavenger
Post14-11-2006, 11:18    Subject: VAG-COM Adapter: Audi A3 8P Car Interface Quote
hey,
My VAG-COM or the adapter seems to be malfunctioning somehow.
"With my Golf 4 (model year 2003), I can do anything I want – access control units, etc."
My friend has an A3 8P, and he can find the control units, but I'm unable to access them.
Sure, here's the translation:
"Do you have any suggestions?"
Best regards.
bitavenger
Translated on 21-08-2026, 7:48.
Herr Antje
Post14-11-2006, 11:20    Subject: VAG-COM Adapter: Audi A3 8P Car Interface Quote
What does "Auto Intern" say about this? I think it's their job to provide support...
Otherwise, is there another interface you can access to manually disable the vehicle?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 21-08-2026, 7:49.
Post14-11-2006, 11:38    Subject: VAG-COM Adapter: Audi A3 8P Car Interface Quote
And if you take a closer look at Auto-Intern, you will realize that for the 8P, you need a CAN-compatible interface.
If your system works with the G IV but not the A3, you definitely don't have a CAN-compatible...
Our host also has the right items for the 8P model in his shop icon_wink.gif.
Translated on 21-08-2026, 7:50.
Ross-Tech-Support
Post14-11-2006, 19:00    Subject: VAG-COM Adapter: Audi A3 8P Car Interface Quote
It has been said before, but the best option would be to contact the provider from whom you purchased your hardware. Besides that, what do you see when you run VAG-COM > Options > Test?
Translated on 21-08-2026, 7:51.
No new posts Automotive Technology: Topics & Resources Technical Articles
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Golf V - Automatic Lock and Automatic Unlock On-Board Diagnostics (OBD)
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts Car Lock Repair: Services & Solutions Diesel Engine Technology
No new posts Hi-tech car, low-tech workshop? Diesel Engine Technology
