Unspectacular Vertical Tube Gymnastics Training, AFN
Klausel
Post26-11-2006, 0:17    Subject: Unspectacular Vertical Tube Gymnastics Training, AFN Quote
Hello!
Mein G3, AFN, wird leider überwiegend Kurzstrecke bewegt. With a stuttering VTG.
Unfortunately, I've had to deal with that before as well. Regular movement of VTG containers is...
advisable. I would like to know how to do it in the most discreet way for Turbo.
Tires, passenger exiting.
The specific question is whether, for example, at very low engine speeds (<= 1300 RPM),...
(5th gear) A brief press of the accelerator pedal is all that's needed to correctly position the variable geometry turbocharger (VGT) control rod.
triggered the attack.
Greetings, Klaus.
Translated on 17-07-2026, 13:04.
neubaupe
Post26-11-2006, 12:30    Subject: Unspectacular Vertical Tube Gymnastics Training, AFN Quote
Hi!
In the VAG-COM 'actuator diagnosis,' one aspect is the VTG (Variable Turbine Geometry) mechanism.
In this exam, she (as far as I know) will be tested for visual acuity.
completely distracted.
Best regards.
Peter.
Translated on 17-07-2026, 13:06.
BM
Avatar-BM
Post26-11-2006, 15:26    Subject: Unspectacular Vertical Tube Gymnastics Training, AFN Quote
The specific question is whether, for example, at very low engine speed (<= 1300 RPM,
moved to the attack.
The VTG rod typically moves to its maximum deflection even when idling.
3B5 AJM
Translated on 17-07-2026, 13:07.
Post26-11-2006, 16:26    Subject: Unspectacular Vertical Tube Gymnastics Training, AFN Quote
[quote="BM"][quote]The specific question is whether, for example, at very low engine speed (<1300> Stop and restart the engine more than 10 times. icon_razz.gif
Translated on 17-07-2026, 13:08.
