Hardware for VAG-COM
Helmut
Post30-10-2002, 22:54    Subject: Hardware for VAG-COM Quote
Does anyone know if the Elektor hardware is compatible with VAG-COM?
In the Elektor section, a microcontroller performs a 'conversion into...'
'Instead of ASCII data.' Other adapters (Ulf) don't need something like that. Maybe.
Has anyone here had experience with ELM and would like to share it?
By the way, you can find the Elektor adapter at www.geist-electronic.de for €75.00.
Helmut.
OlliP
Post31-10-2002, 14:42    Subject: Hardware for VAG-COM Quote
according to Gerhard Müller, the author of the 'Elektor' article, is working.
The adapter only works with the included software or with a...
standard terminal program. Other software, such as VAG Com.
It's not working!
CU
Olli.
No new posts Subaru Diagnostics: Using VCDS Hardware Troubleshooting & Guides
No new posts Hardware Spray Start: How to Begin Diesel Engine Technology
No new posts Kleiner Hardware-Vorschlag On-Board Diagnostics (OBD)
No new posts What ready-made hardware is available for VagCom? Diesel Engine Technology
No new posts VCDS Hardware update möglich ? On-Board Diagnostics (OBD)
