Coolant loss AFN under full load --> Is it a leak?
christox
Post03-12-2006, 20:16    Subject: Coolant loss AFN under full load --> Is it a leak? Quote
Hello!
After reviewing all the possible posts on this topic about coolant loss, my suspicions are now also pointing towards the cylinder head gasket.
First, let's start with the initial situation:
-Coolant reservoir was at max.
-This involved a significant amount of full-throttle driving over the 500km distance.
-Now, the level in this period has decreased by approximately 3/4 liters.
-After a long drive, a hissing sound can be heard when the coolant reservoir cap is closed.
-When the lid is then opened, it makes a relatively quiet sound. So, as if the pressure isn't high enough.
-after releasing the pressure and 1 km 'Give him' is this hissing sound, and when opening
only escapes very little pressure.
-No traces of coolant leakage in the engine compartment, even under the car.
-Oil level remains constant.
-No gas bubbles were observed in the open container when the system was at rest.
-Coolant is clear without oil inclusions.
Maybe you could also provide me with some testing methods that can lead to the cause.
Could it be that the valve in the cap is opening too early, which is causing the hissing?
But then, there should be traces of the frost protection around the lid to be seen.
Or should I prepare for a ZKD swap?
Does anyone have a repair guide for this hard drive replacement?
It would be great if someone could help me, because only driving part-time to save water and antifreeze is no longer fun icon_wink.gif
Best regards, and have a nice evening. Christox
Held467
Post03-12-2006, 20:58    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]
Hallo
eventuel ist ja nur der Deckel defekt weil er nicht viel Druck auf dem System hat, bei ZKD oder ZK würde er soviel Druck machen das es richtig zischt und übersprudelt.
Ich würd erstmal nen neuen/anderen Deckel testen.
Mfg. Dirk
christox
Post03-12-2006, 21:14    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]Ok, das werde ich wohl zuerst machen bevor ich den Kopf öffne.
MfG, Christox
christox
Post04-12-2006, 15:35    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]So, der Deckel war es natürlich nicht !
Habe mit neuem Deckel heute auf der AB mit Vollgas über 20 km etwa nen halben Liter Kühlwasser verblasen.
Auf dem Rückweg mit konstanten 120 km/h Null Kühlwasserverbrauch !
Spricht nun also alles für die ZKD, oder Haarriss im Zylinderkopf.
Hat jemand eine Anleitung für den Wechsel der ZKD oder des Zahnriemens beim AFN ? Bzw. Drehmomentvorgaben ?
Welche Schraubenköpfe haben denn die ZK-Schrauben ? sind das Aussentorx ?
Was benötigt man für Spezielwerkzeug, ausser den Arretierwerkzeugen für den Zahnriemen ?
Wäre nett, wenn mir jemand weiterhelfen könnte, denn die 1000,- für die Reparatur beim Freundlichen hat man als Student nicht auf die Schnelle
MfG, Christox
Arno
Post04-12-2006, 17:49    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]Hallo.
Scheint so als ob bei den AFN los Wochos wären icon_confused.gif .
Habe bei meinem bepölten AFN (Eintank) z.Zt. das gleiche Phänomen. Seit einiger Zeit verliere ich bei höherer Last auch KW. KW-Deckel wurde aber auch schon überprüft -> OK. Allerdings verlege ich den SB bei Kaltlauf und Niedriglast manuell recht stark nach vorne. Seltsamerweise (oder logischerweise icon_exclaim.gif ) habe ich bei vorverlgtem SB mehr bzw. eher Kühlwasserverlust als bei normalem SB. Durch die Vorverlegung steigen die Spitzendrücke unweigerlich an, dadurch können sich dann auch eher Verbrennungsgase ins KW mogeln als bei 'normalen' Druckverhältnissen. M.M.n. deutet dies auf eine langsam schwächelnde ZKD hin. Bei LL und höheren Drehzahlen hab ich keine Blasen im Ausgleichsbehälter. So ein 'Test' bei Nulllast ist aber ohnehin nicht sehr auussagekräftig. Das KW riecht auch nicht nach Abgasen.
Interessant wären weitere Infos zu Laufleistung, wieviel davon mit PÖL, Fahrprofil, evtl. Änderungen am Einspritzsystem (mechanisch,manuell, softwareseitig, etc...).
christox
Post04-12-2006, 19:05    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]n Abend Arno!
Mein Passat hat 140Tkm drauf, wovon 5000 km mit Pöl laufen.
Der Spritzbeginn wurde mittels Adaption trotz 2-Tank um 1.5° frühverlegt, was ja nichts ist im Gegensatz zu 1-Tank anpassungen mit 4° frühverlegung.
Oder siehst DU das schon als 'Gefahrenherd' für ZKD-Schäden ?
Sollte ich den SB wieder Auf Standard setzen, und das KW beobachten, oder lieber gleich die Sache richtig angehen und tauschen.
...Suche noch immer Tips zum ZKD-wechseln...
MfG, Christox
BM
Avatar-BM
[Translating...]
Ich denke, dass es zu 80% mit der ZK, evt. Kopf schleifen erledigt ist.
Zur Reparatur sollte sollte ein Fachmann verfügbar sein.
3B5 AJM
Arno
Post05-12-2006, 0:21    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
1,5° halte ich IMHO auch für unkritisch, vor allem bei PÖL. Dagegen ist meine Vorverlegung ja jenseits von gut und böse icon_redface.gif .
/viewtopic.php?t=11731
/viewtopic.php?t=2182
Die beiden Threads sind m.E. am hilfreichsten zur Feststellung und Behebung des Problems. Zumindest bei meinem Prob icon_cool.gif .
christox
Post05-12-2006, 17:12    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]der zweite Link ist echt sehr Hilfreich, Danke !
Habe heute bei einem Kumpel in der Werkstatt das KW-System mit 2bar abdrücken lassen --> Dicht.
Ausserdem haben wir den CO-Test gemacht, welcher negativ ausfiel. Sogar von meinem Atem verfärbte sich die Testflüssigkeit stärker, als von den Kühlwasserdämpfen.
Kann ich durch diesen CO-Test eine Leckage der ZKD ausschliessen ?
Das Öl steigt nicht an, und bildet keinen grauen Schleier.
Das KW sank heute bei 140km/ über 50 wieder km nicht. Bei Vollast jedoch.
MfG, Christof
BM
Avatar-BM
Post06-12-2006, 2:03    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]
Was willst du mit 2bar denn abdrücken? Um eine Leckage im ZK bzw ZKD nachweisen zu können, müsstest du schon einen Druck aufbauen, welcher dem
Verbrennungsdruck gleich kommt.
Theoretisch --> Ja, Praktisch --> Leider Nein
Lies mal hier:
/viewtopic.php?t=13961&start=0&postdays=0&postorder=asc&highlight=
/viewtopic.php?t=12300&start=0&postdays=0&postorder=asc&highlight=
/viewtopic.php?t=13083&start=0&postdays=0&postorder=asc&highlight=
Es handelt sich zwar um PD Motoren, die Problematik ist aber die Gleiche , wie bei den VE Motoren.
3B5 AJM
christox
Post06-12-2006, 10:11    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
--> Nur das KW-System gegen Atmosphäre. Denn nach dem CO-Test waren die in der Werkstattt der Meinung, daß es entweder in das Öl oder durch ein Leck nach draussen entweichen müsste.
Habe mich vielleicht nicht richtig ausgedrückt.
Die einzigen Spritzerchen KW sehe ich unter dem KW-Behälter.
Dort sammelt sich am Überlaufstutzen unten immer ein Tropfen an, wahrscheinlich kondensierter Dampf.
Jetzt bleiben mir nur noch 2 Möglichkeiten:
a) das Pöl-2Tankgeraffel ausbauen und Nachbesserung vom Verkäufer fordern, da Wagen vor 5 Monaten von gewerblichem Händler gekauft.
b) Pöl-2Tankgeraffel nicht ausbauen, und mich mit ZKD, Wapu, Schrauben und Zahnriemenkit bewaffnet für ein Wochenende in die Garage zurückziehen.
Variante a) ist noch mit einigem Ärger verbunden, da der Händler mir eine Gebrauchtwagengarantie angedreht hat, nach welcher ich schon 2 Servicetermine 'versäumt habe'.
Diese WENA-Garantie besteht auf Service bei Vertragshändlern und will den Stempel per Postkarte zugeschickt bekommen.
Doch die gesetliche Gewährleistung des Verkäufers besteht doch auch ohne diese Services, oder ?
MfG, und Danke für eure Hilfe
christox
Post06-12-2006, 13:37    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]Jetzt habe ich Gewißheit:
--> bei warmem Motor Druck aus dem Kühlwasserbehälter abgelassen.
--> nach 10 km Vollgas auf der AB war der Motorraum voller Danpf, kam alles aus dem Überdruckventil des Deckels. Nach öffnen des Deckels entweichen Gase, und der Flüssigkeitspegel steigt dadurch im Behälter an. Eine Schnupperprobe roch nach Abgasen.
mserge
Post06-12-2006, 15:16    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]
Halso doch die ZKD.
Was den CO2 test angeht.
Beim testen muss du ein paar mal richtig kräftig Gas geben damit der Motor richtig Druck aufbaut (ist zwar schwer im leerlauf, aber trotzdem). Danach wird er dann auch CO2 anzeigen, aber das hat sich ja jetzt schon erledigt.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
BM
Avatar-BM
Post06-12-2006, 16:25    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]
Da verwechselst du Garantie und Gewährleistung.
Die Gewährleistung bezieht sich auf Mängel, die bereits bei der Übergabe vorhanden sind/waren. Und wenn die ZKD bei Übergabe schon defekt war, hättest du sofort einen Wasserverlust (der dann schon bestanden hätte), bemängeln müssen. Scheinbar war das aber nicht der Fall. Deshalb meine Meinung --> juristisch keine Chance.
3B5 AJM
christox
Post14-12-2006, 12:55    Subject: Coolant loss AFN under full load --> Is it a leak? Translating...
[Translating...]Hallo!
So, der Kopf ist nun unten.
An der Kopfdichtung kann man nicht viel erkennen, ausser, dass sie an 2 Wasserkanälen stärker korrodiert ist. Aber die beiden äusseren kolben sind an der Seite, an der die Wasserkanäle verlaufen grossflächig weiss verfärbt.
Ist das also ein Indiz für Wassereindrang in den Brennraum ?
Habe den Kopf nun zum Planschleifen und abdrücken gebracht und morgen kommt er wieder rein...
MfG, Christox
No new posts Coolant leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Leak Audi A6 2.5 TDI:( Diesel Engine Technology
No new posts Coolant leak 1.6 TDI Diesel Engine Technology
No new posts kurioser Kühlwasserverlust (AFN) Diesel Engine Technology
No new posts Kühlwasserverlust - am Temperatursensor Diesel Engine Technology
