cabii
25-02-2011, 23:35 Subject: ALH Engine Control Units: Questions & Answers |
Hello, I need some information. I have an Ibiza ALH.
Control unit defective, part number: 038 906 018 EE.
"Now I'm looking for a used part like that, but I can only find ones with a different ending. Can I use one with a different ending, or even a completely different part?"
Translated on 10-10-2026, 4:50.
Herbert Profi-Schrauber
25-02-2011, 23:50 Subject: ALH Engine Control Units: Questions & Answers |
With very few exceptions, no. See, for example:
/viewtopic.php?p=181889#181889
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Herbert. Horch A4 8K CJCD
Translated on 10-10-2026, 4:51.
cabii
26-02-2011, 0:12 Subject: ECU Remapping: Improve Engine Performance |
That means I need the exact part with "EE" at the end.
So, I can't, for example, use part number 038906018 AE? It also comes from a Golf 4, specifically an ALH engine.
Translated on 10-10-2026, 4:52.
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
26-02-2011, 9:43 Subject: ALH Engine Control Units: Questions & Answers |
The car will run, but the question is how, because there are enough small details that could lead to errors, such as:
- Flashing preheating lights with emergency program.
- irreversible errors.
- Jerky movement, poor performance due to other expected sensors/transducers.
They can express themselves. Whether it works flawlessly is like playing the lottery. Even loading the corresponding dataset doesn't always help; I've observed this myself with 038906018AE and BA (apparently identical hardware). -> The input circuit for at least the mass airflow sensor (MAF) was different.
Everything has been discussed a thousand times, but the VAG part number always includes letters!
Translated on 10-10-2026, 4:53.
Profile PM WWW Garage |
26-02-2011, 12:23 Subject: ALH Engine Control Units: Questions & Answers |
The only way is to consult the vehicle-specific repair manual for the VW fuel injection system (specifying the model, engine, and year of manufacture). It may be possible to replace older ECUs with a newer one that covers a group of older models.
For example, in the Audi 80B4 with engine code 1Z, the MSG 028 906 021 FE (MSA15) replaces the MSGs 028 906 021 G and 028 906 021 AP (both MSA12). However, to downgrade from MSA15 to MSA12, it is crucial to know which MSG is associated with which specific equipment configuration.
The MSG (Modular System Group) for a Golf with a 1Z engine has a completely different design and is therefore not interchangeable with Audi parts.
The same applies to an ALH engine.
"vg"
Translated on 10-10-2026, 4:55.
