acuransx wrote: |
| I have an ASZ engine (now ARL). However, my general concern is whether this can be considered accurate, because with other engine codes, the measurement block might be located elsewhere. |
It's a bit complicated. The displayed value doesn't account for internal friction or auxiliary components of the engine, so it's usually not very informative. You can tell this because the reading is already greater than zero even when the engine is idling.
