AFN Conversion: Turbocharger Boost Tap?
helios2000
Post10-05-2007, 10:45    Subject: AFN Conversion: Turbocharger Boost Tap? Quote
Hello everyone,
I'm having the following problem with my car (a Vento TDI).
The car received an AFN engine (previously had a 1Z), but it's still from the previous owner.
Okay, the problem is that the turbocharger stops working at 3000 RPM until it restarts. I've researched this in many forums, and it seems there's a hose that runs from the control unit to the engine. The hose is connected to the control unit, but it's just hanging loose in the engine compartment. Where does this hose need to be connected?
Can anyone help me with that? That would be great.
Thank you, Mirko.
Translated on 24-10-2026, 7:28.
Post10-05-2007, 11:21    Subject: AFN Engine Problems: Troubleshooting & Solutions Quote
helios2000 wrote:
Now the problem is that the turbo simply stops working at 3000 RPM until it restarts. I've already found out through many forums that there's a hose from the control unit to the engine. It's connected to the control unit, but it's just hanging loose in the engine compartment. Where does this hose need to be connected?
"On my G3 AFN, it was attached to the plastic intake pipe, roughly above the gearbox. There's a nipple there for the hose to connect to."
In your case, when converting from a 1Z to an AFN engine, things might look different...
Translated on 24-10-2026, 7:30.
No new posts T4 conversion, 2.5 TDI, ESP, ACV Diesel Engine Technology
No new posts AKE to EU3 Conversion for A6 Diesel Engine Technology
This topic is locked, you cannot edit or reply. PDE Renovation: Complete Transformation Diesel Engine Technology
No new posts 1Z Refurbishment Diesel Engine Technology
