Causes of the shaking, Engine is shaking (Solution)
Post02-05-2002, 13:35    Subject: Causes of the shaking, Engine is shaking Quote
Malfunctions at specific RPMs, check:
- Needle lift activator (only older TDI engines with distributor-based fuel pump)
If this is temporarily out of service, it should be recorded in the fault memory. Irregular engine failures of varying lengths:
- Check relay '109'. The number can also be different depending on the model, the relay supplies power to the engine control unit.
Ratings - Causes of the shaking, Engine is shaking
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine diesels, and it's jerking while running! Diesel Engine Technology
No new posts Engine Misfire: Troubleshooting & Error Codes On-Board Diagnostics (OBD)
No new posts SQ5 is shaking Diesel Engine Technology
No new posts BMP is twitching Diesel Engine Technology
