Boost Pressure Sensor 1Z
HJGriessmeier
Post03-04-2008, 16:04    Subject: Boost Pressure Sensor 1Z Quote
Hello everyone,
I have a question that someone might be able to answer. I purchased an external pressure sensor (300 kPa) from the shop.
Okay, here's the translation:
'Now my question: Do I need to completely desolder the old sensor from the control unit, or can I directly connect the cables from the external sensor to the corresponding connectors?'
Translated on 29-08-2026, 4:52.
Post03-04-2008, 16:25    Subject: Boost Pressure Sensor 1Z Quote
According to the included pinout diagram, 3 of the connectors instead of the original boost pressure sensor can be directly connected to the control unit (ground, +5V, signal voltage).
It's easiest to use the original charge air temperature sensor and not the one integrated into the external sensor.
Warning: The engine control unit (ECU) software needs to be adjusted to match the other sensor, and that's a job for your tuner.
Well, he should actually know how to connect the sensor...
Translated on 29-08-2026, 4:54.
HJGriessmeier
Post03-04-2008, 16:35    Subject: Boost Pressure Sensor 1Z Quote
Thank you for the quick response. Yes, it took a little while for me to finish the box. icon_biggrin.gif
'I've been using the integrated charge air temperature sensor for a while now, and it's working perfectly. Since I have a completely new piping system, I didn't want to install two connections if I could also do it through the combination sensor from you. I haven't had any problems with it, so I think the temperature values that the Bosch computer is displaying are plausible. In your opinion, what would be the advantage of keeping the old sensor? Or what would be the disadvantage of the new one?'
Translated on 29-08-2026, 4:55.
Post03-04-2008, 17:07    Subject: Boost Pressure Sensor 1Z Quote
What, in your opinion, should be the advantage of keeping the old one?
Well, now that we've established that nothing needs to be changed? Unfortunately, the input values are not always the same.
Translated on 29-08-2026, 4:56.
HJGriessmeier
Post04-04-2008, 12:38    Subject: Boost Pressure Sensor 1Z Quote
Yes, you're right. But as I said, it's already in use and it's also working.
I will be commissioning the pressure sensor within the next 14 days and will give you a brief update on whether everything worked as expected.
Thank you.
Best regards, Hansi.
Translated on 29-08-2026, 4:57.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Sensor in ECU? Diesel Engine Technology
No new posts Boost Pressure Sensor (Engine Control Unit) Diesel Engine Technology
No new posts Boost Pressure Sensor Audi Diesel Engine Technology
No new posts Boost Sensor for MSA12/15 & Vacuum Systems Diesel Engine Technology
