AGR Golf 5 105PS: Engine Management System
Post24-04-2007, 16:24    Subject: AGR Golf 5 105PS: Engine Management System Quote
Does this actually happen often? I've never experienced it before, and there's really nothing that could possibly be loose or move around.
 File size:  88.65 KB
 Viewed:  6630 times
Translated on 18-09-2026, 9:16.
Post24-04-2007, 16:29    Subject: AGR Golf 5 105PS: Engine Management System Quote
Wow... what a mess!
Yesterday, I had a car parked next to me that was making an incredibly loud noise, to the point where I almost wanted to tell the driver. But he probably wouldn't have understood anyway... he was really flooring the accelerator.
How was the connection established before it was disconnected?
- Are you bored?
- A part?
Translated on 18-09-2026, 9:17.
Post24-04-2007, 18:59    Subject: AGR Golf 5 105PS: Engine Management System Quote
How was the connection established before it was broken?
- Are you bored?
- A part ?
In that location, there's a type of metal bellows that allows the pipe to be installed.
Meanwhile, the reason why the bellows had torn has been found: an M6 Allen screw was lying on the floor. It was one of the screws used to secure the AGR pipe flanges.
Because the bellows were only attached on one side, they started to expand under pressure, and eventually, they simply broke.
Translated on 18-09-2026, 9:18.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post24-04-2007, 19:58    Subject: AGR Golf 5 105PS: Engine Management System Quote
"I've seen this happen several times (about 5 times) with Audi vehicles, causing the AGR pipes to leak directly at the flange. However, it doesn't seem to be a widespread problem due to the relatively low production numbers. What's more common is cracking in the exhaust manifolds, especially in tuned vehicles."
B.Eng (FH) u. KFZ Meister
Translated on 18-09-2026, 9:20.
Post24-04-2007, 21:55    Subject: AGR Golf 5 105PS: Engine Management System Quote
What is more common are cracks in the exhaust manifold, especially in tuned vehicles.
130ps PD-TDI
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can you disconnect the AGR (Automatic Gearbox) from a 105... Diesel Engine Technology
No new posts Frage zum aktuellen 105PS TDI Diesel Engine Technology
No new posts ASZ engine in Golf 2 Diesel Engine Technology
No new posts Golf TDI 4: Buying Guide & Engine Info Diesel Engine Technology
