dj1 Guest
09-04-2007, 10:20 Subject: TDI Spark Plugs: 100 for Your Car? |
I had a custom exhaust system made (70mm diameter from the turbo), and now I'm wondering if I should install a catalytic converter after all.
You're probably wondering, 'Which one?'
Can the 100-cell catalytic converters (which are also used for VR6 turbos) be used?
Has anyone had any experience with that?
Thank you in advance for any tips!
DJ1
Translated on 20-09-2026, 13:44.
mdonau Blaumann
Joined: 01/01/2005 Posts: 248 Karma: +5 / -0 Location: 24939 1988 Audi 80 Premium Support
09-04-2007, 13:09 Subject: TDI Spark Plugs: 100 for Your Car? |
No, that's not possible.
http://de.wikipedia.org/wiki/Fahrzeugkatalysator
So: Either take it out (illegally) or leave the original one in.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 20-09-2026, 13:45.
Profile PM Garage |
dj1 Guest
09-04-2007, 15:11 Subject: TDI Spark Plugs: 100 for Your Car? |
Hmm, I've just skimmed through the texts:
'In a diesel engine, the excess oxygen in the exhaust gas prevents the reduction of NOx and necessitates the use of specialized catalysts.'
If the diesel engine has sufficient power and therefore operates without an excess of oxygen?
I once inquired with a seller of 100/250-cell catalytic converters, and they mentioned that they had already sold some to TDI drivers, which makes me a bit uncertain.
DJ.
09-04-2007, 15:14 Subject: TDI Spark Plugs: 100 for Your Car? |
dj1 wrote: | | But what if the diesel engine has sufficient power and therefore operates without an excess of oxygen? |
It already smokes like crazy with a "mass lambda" setting of 1.
Nowadays, one would only subject the audience to such a thing for a limited time, perhaps on a racetrack.
Translated on 20-09-2026, 13:47.
Profile PM Garage |
a dancer Blaumann
Joined: 09/07/2006 Posts: 55 Karma: +2 / -0 Location: Wertheim
09-04-2007, 18:36 Subject: TDI Spark Plugs: 100 for Your Car? |
There are special 100-cell catalytic converters for diesel engines.
Unfortunately, I don't remember the link right now. Just do a quick Google search...
Jochen_145 Guest
09-04-2007, 20:28 Subject: TDI Spark Plugs: 100 for Your Car? |
Check out HJS!
http://www.hjs-motorsport.de/produkte_partikel.php
There are DPFs (Diesel Particulate Filters) specifically designed for racing. Furthermore, a simple email or phone call will quickly clarify the purpose and necessity of a 200-cell catalytic converter.
They also have extensive knowledge in the diesel sector.
The city filter, depending on the model, is a DPF combined with a catalytic converter.
Furthermore, HJS has extensive experience with diesel engines in motorsports.
Best regards, Jochen.
Translated on 20-09-2026, 13:48.
dj1 Guest
11-04-2007, 11:36 Subject: TDI Spark Plugs: 100 for Your Car? |
Okay, I've made a few phone calls and found out the following:
So, there are special 100-cell diesel catalytic converters (with a special coating), and I'll be getting more information about them next week (according to Mike Rohte).
Hjs-Motorsport believes that standard 100-cell catalytic converters are also suitable for diesel engines, provided that they are not used for motorsport events.
DJ.
Translated on 20-09-2026, 13:49.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
11-04-2007, 19:29 Subject: TDI Spark Plugs: 100 Brands for Sale |
dj1 wrote: | Hello,
You're probably wondering which one...
DJ1 |
Hello, if 100 cells are good, then 200 are even better.
Can't you use the catalytic converter from the 2.5 TDI? It has a diameter of 170 mm and...
"With a 62/65 mm pipe, the back pressure shouldn't be more than half of what it is in the standard configuration, right?"
derteileklaus
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 20-09-2026, 13:51.
Profile PM Email Garage |
dj1 Guest
11-04-2007, 19:48 Subject: TDI Spark Plugs: 100 for Your Car? |
Hmm, I've also been considering getting one with a 'large diesel' engine.
BMW 535d or Audi.
I need to take a look...
Translated on 20-09-2026, 13:52.
