Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
30-04-2007, 13:14 Subject: Edited: Seat Ibiza AFN - No more power, permanently |
Here's the file from Misiu again, and this time it's readable.
| Description: |
 Download |
| File name: |
LOG-01-004-Einspbg.xls |
| File size: |
85 KB |
| Downloaded: |
660 times |
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Joined: 04/12/2002 Posts: 18064 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
02-05-2007, 10:50 Subject: Edited: Seat Ibiza AFN - No more power, permanently |
If you continue to delay the start of the injection process, you will soon be greeted by your ZKD...
Is the timing belt tension okay? Can you see any traces of mouse remains or blood on the timing belt (in case the AFN cover isn't completely sealed)?
Please check this, along with the basic settings: NW (negative crank angle), OT (top dead center) for cylinder 1, and the positioning of the fuel injection pump. I would do that before starting it up again.
In my opinion, either the ESP system is malfunctioning or the timing belt has slipped.
Profile PM WWW Garage |
