Edited: Seat Ibiza AFN - No more power, permanently
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
Herr Antje
Post30-04-2007, 13:14    Subject: Edited: Seat Ibiza AFN - No more power, permanently Quote
Here's the file from Misiu again, and this time it's readable.
LOG-01-004-Einspbg.xls
 File name:  LOG-01-004-Einspbg.xls
 File size:  85 KB
 Downloaded:  679 times
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Post02-05-2007, 10:50    Subject: Edited: Seat Ibiza AFN - No more power, permanently Quote
If you continue to delay the start of the injection process, you will soon be greeted by your ZKD...
Is the timing belt tension okay? Can you see any traces of mouse remains or blood on the timing belt (in case the AFN cover isn't completely sealed)?
Please check this, along with the basic settings: NW (negative crank angle), OT (top dead center) for cylinder 1, and the positioning of the fuel injection pump. I would do that before starting it up again.
In my opinion, either the ESP system is malfunctioning or the timing belt has slipped.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts No more power, permanently - Seat Ibiza AFN LOG MWB 004 ESB Upload
No new posts Seat Ibiza stopped working after battery replacement. Electrical Systems, Vehicle Electronics, Multimedia
No new posts Probleme Ibiza TDI /Wenn Klima an keine Leistung Diesel Engine Technology
No new posts jetzt hat er gar keine Leistung mehr Diesel Engine Technology
