Hello community,
I'm new here and I've also tried using the search function repeatedly, but unfortunately without success.
I replaced the timing belt and camshafts on my Audi (AKE, 132 kW), and then, after the work was completed, I initially attached the timing belt pulley to the center position on the timing belt pulley (as determined by measurement).
The engine is running smoothly, requires less diesel, so far, so good.
Now, as a conscientious amateur mechanic, I naturally also want to correctly set the injection start time. Fortunately, I have a VAG-COM version 409-1 available for this purpose.
1. Problem: With this version, only TDI Graph 1.3 runs, and it doesn't have my MKB (Marketplace) available.
2. In the table "Troubleshooting with VAG-COM", which I downloaded here, the target values in the measurement block 4 for the AKE- engine only show empty fields.
Who of the professionals can briefly and understandably explain how to adjust the injection start time using this block (there is no injection start time graph for my TDI engine)?
The following works: In MWBl. 4, after switching to the basic state, there is a transition between late and early, with late being displayed as 0.5 grd and early as 12grd.
In normal mode, the target value increases from early to late as the speed increases (shouldn't this be reversed?). The "is" value remains at 12 degrees before OT and does not change at all.
If the vehicle was not running properly, one should suspect a complete misconfiguration here.
Who can help?
Greetings
