AFN 110 PS: Cold Start Problems & Solutions
DannyMueller
Post03-07-2007, 20:47    Subject: AFN 110 PS: Cold Start Problems & Solutions Quote
Hello experts,
I'm having a problem. My SEAT Ibiza is difficult to start when the engine is warm.
When I get into the car in the morning and turn the key, it starts right away.
If I then, for example, drive 50km and then try to start it, I have to crank it for almost a minute, but then it eventually starts.
How can this be improved, or is this "normal"?
Can anything be done with VAGcom? According to VAGcom, no errors are present.
Could this be related to the start of the injection process?
Unfortunately, I was unable to use the search function because I received an error message that said "Server load appears to be too high."
Translated on 08-10-2026, 9:00.
Post03-07-2007, 21:32    Subject: AFN 110 PS: Cold Start Problems & Solutions Quote
Okay, now search for "warmstartproblem".
But "one minute" is a very long time; it probably isn't the typical warm-start problem for VP TDIs.
Translated on 08-10-2026, 9:01.
Post03-07-2007, 21:38    Subject: AFN Engine: Cold Start Problems & Solutions Quote
DannyMueller wrote:
Unfortunately, I was unable to use the search function because it displayed an error message: "Server load appears to be too high"
/viewtopic.php?t=11189&highlight=warmstartproblem
Translated on 08-10-2026, 9:02.
DannyMueller
Post04-07-2007, 7:32    Subject: AFN 110 PS: Cold Start Problems & Solutions Quote
Thank you for your help. I think we should delete this topic, as some people are experiencing these problems.
"1 minute was the estimated time, but waiting always seems to take longer."
Basically, as far as I understand it now, the only legal way to fix the problem is to replace the starter motor.
Translated on 08-10-2026, 9:03.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Sliding Door: Repair & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine: Starting Problems & Troubleshooting Diesel Engine Technology
No new posts Opel Astra: Cold Start Problems - 1.7TD Fix Diesel Engine Technology
No new posts Van engine T4 ACV starts poorly in both warm and cold con... Diesel Engine Technology
No new posts ASZ starts warm, runs poorly - what could it be? Diesel Engine Technology
