Engine Knocking: Causes & Solutions
Corvetto
Post23-05-2007, 21:00    Subject: Engine Knocking: Causes & Solutions Quote
Hello everyone!!
"I've been experiencing the following problem with my Audi 100 AAT, 2.5 TDI for some time now..."
"When I start the car in cold weather, I sometimes hear a relatively loud clicking sound coming from the engine compartment. This sound then diminishes as the engine temperature increases, until it becomes almost inaudible."
At the same time, the engine is running slightly unevenly, and when it's warm, you can hear a kind of "muffled thumping" sound, which is quite faint if you put your ear near the oil filler cap.
The oil pressure seems to be okay, as the warning light goes out immediately when the starter is first turned. I would rule out bearing damage, as that usually gets louder with temperature... even under load, the engine is quiet, with no noises coming from the crankcase.
The car uses almost no engine oil.
It's definitely not a vacuum pump...
I've also opened the fuel injection lines while the engine is running, and the RPM drops equally for each cylinder.
My question is: could a faulty hydraulic lifter cause that?
If a hydraulic lifter is completely seized and can be compressed, wouldn't that cause the valve to have less lift, potentially leading to an uneven or erratic engine running?
Please provide advice, suggestions, etc.
Thank you!!!
Audi 100 C4, Bj 1993, MKB: AAT
Translated on 23-10-2026, 8:48.
christians
Post25-05-2007, 12:00    Subject: Engine Knocking: Causes & Solutions Quote
Yes, that could be. However, the rumbling is independent of that and is generally normal.
Gruß Christian
Translated on 23-10-2026, 8:50.
Corvetto
Post29-05-2007, 19:39    Subject: Engine Knocking: Causes & Solutions Quote
Hello everyone...
Okay, now I know what's making that clicking sound.
The vibration damper has come loose, and in the process, it has damaged a corner of the crankshaft... what now?
"Thank you!"
No new posts Engine Clicking Noise: Causes & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine RPM at Cold Start: What's Normal? Diesel Engine Technology
No new posts Boost Pressure: Cold Engine & >2500 RPM Diesel Engine Technology
No new posts Compression test: warm or cold engine? Diesel Engine Technology
No new posts Cold Engine Start: How Bad Is It? Diesel Engine Technology
