VP37 Pump Connector Pinout: Wiring Diagram
suggermilk
Post26-11-2002, 22:29    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
I've developed a 10-cent tuning method that incorporates a delay.
I am familiar with the connection for the eight-pin connector.
Resistance in cables 2 and 3, and turn-on delay in cables 4 and 5 (corresponding to positive and negative).
I need the information for the 10-pin connector.
-I understand that the resistance will appear again in parts 2 and 3.
Where is the positive and negative terminal on a 10-pin connector?
Does anyone have a wiring diagram?
Translated on 23-09-2026, 7:07.
Rudi
Post26-11-2002, 23:15    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
You have mail icon_twisted.gif.
Best regards, Rudi.
Translated on 23-09-2026, 7:08.
suggermilk
Post26-11-2002, 23:47    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
@ rudi
No, I haven't received any messages from you.
Does anyone know where the positive and negative terminals are located on the 10-pin connector?
Translated on 23-09-2026, 7:09.
Rudi
Post27-11-2002, 9:24    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
Hmm...
I emailed it to the address you provided ([email protected]), and I haven't received anything back yet. icon_question.gif icon_question.gif icon_question.gif
Pin 1 signal, rule slider position sensor, G149, reference coil.
Pin 2 'Power Supply' potentiometer G149.
Pin 3 signal, control slide, G149 measurement coil.
Pin 4: Sensor ground.
Pin 5 supply, N146 (quantity control).
Pin 6 controls N146 (flow control valve).
Pin 7: Fuel temperature signal, sensor G81.
Pin 8: Fuel shut-off valve control (N109).
Pin 9 controls N108 (fuel injection start valve).
Pin 10 supplies voltage to N108 (fuel injection start valve).
Best regards, Rudi.
Translated on 23-09-2026, 7:10.
suggermilk
Post27-11-2002, 10:46    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
Do you also have the data for comparison for the eight-pin connector?
That would be really great, because then all my problems would be solved.
Translated on 23-09-2026, 7:12.
Rudi
Post27-11-2002, 11:25    Subject: VP37 Pump Connector Pinout: Wiring Diagram Quote
Here's the number 8:
Pin 3 Signal, Control Slider Path Sensor, G149 Measurement Coil.
Pin 8 not used.
Best regards, Rudi.
Translated on 23-09-2026, 7:13.
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts VP37 Pump Pinout: Diagram & Information On-Board Diagnostics (OBD)
No new posts Pump Connector Part Number: Find Yours Now! Diesel Engine Technology
No new posts 98'AFN 8-ofor the 10-pin pump connector? Diesel Engine Technology
No new posts Motor Running Without Pump Plug? Diesel Engine Technology
