VTG Loader Oil Supply: Retrofit & Optimization
Stef@n
Post28-06-2007, 14:45    Subject: VTG Loader Oil Supply: Retrofit & Optimization Quote
hello!
Do you know of a good place where I can have my loader modified so that the oil inlet and outlet are swapped, and perhaps also have the clearance optimized at the same time?
Greetings and thank you for your help.
Translated on 28-09-2026, 7:54.
Karma: +807 / -0   Thank you, like it!
Post28-06-2007, 16:37    Subject: VTG Lube System: Retrofit, Optimization & Supply Quote
Stef@n wrote:
hello!
greetings and thank you for your help
Here. The loader must be working correctly. However, I don't optimize the clearance, as it's a delicate matter. If the clearance is too small, it can potentially lead to unwanted chip-lifting during the machining process.
"Failed" indicates that the VTG (Variable Turbine Geometry) pre-adjustment is compatible with the installed turbocharger/setup.
Translated on 28-09-2026, 7:55.
Stef@n
Post28-06-2007, 16:54    Subject: VTG Loader Oil Supply: Retrofit & Optimization Quote
Basically, the issue is that where the oil inlet is currently located, the oil outlet will be located later, because I've installed my loader upside down.
I would like to send you a new charger to replace the one you have. What will it cost me?
Translated on 28-09-2026, 7:56.
Post28-06-2007, 18:47    Subject: VTG Loader Oil Supply: Retrofit & Optimization Quote
PM.
Translated on 28-09-2026, 7:57.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts VW Lupo 1.4 TDI: Engine Problems & Performance Issues On-Board Diagnostics (OBD)
No new posts Sick Leave: Questions & Options? Diesel Engine Technology
No new posts Sport Exhaust Group A? Diesel Engine Technology
No new posts TDI Fuel Injector: Help Needed in Bad Sobernheim Diesel Engine Technology
