Golf TDI: When was the emissions light installed?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post24-06-2007, 17:06    Subject: Golf TDI: When was the emissions light installed? Quote
"Hi, but in which production year was the emissions warning light installed in the Golf 4 TDI? I have a Golf 4 TDI 150 hp with engine code ARL and 4Motion, manufactured in 02/02, and the warning light doesn't illuminate when I turn on the ignition. However, a friend with an ASZ engine, manufactured in 06/03, has the light coming on."
"This issue also doesn't appear during the actuator test (engine control unit) on my car, but it does on my friend's car, which then displays the message 'Engine fault, workshop required'."
I'm really curious why this isn't lighting up for me.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi SQ5 8R Cvub
Translated on 18-10-2026, 3:21.
Back to top Profile PM Email
Ross-Tech-Support
Post24-06-2007, 19:23    Subject: Golf TDI: When was the emissions light installed? Quote
Keyword: Introduction to EOBD. icon_cool.gif
Translated on 18-10-2026, 3:22.
pa-mm6
Post24-06-2007, 20:17    Subject: Golf TDI: When was the emissions light installed? Quote
Hi.
"That's strange, it should have already been available from the 2002 model year. However, I can't read any reasonable values using VAG-COM on either vehicle via OBD. Is this only related to the engine control unit, or are there other factors involved? Both vehicles have the Euro 3 emissions standard."
Audi SQ5 8R Cvub
Ross-Tech-Support
Post24-06-2007, 20:22    Subject: Golf TDI: When was the emissions light installed? Quote
pa-mm6 wrote:
...it's strange, it should have already been available on the model 02.
Not with diesel.
http://obd-2.de/techn.html
pa-mm6 wrote:
However, even with VAG Com, I can't read any reasonable values via OBD on the new model. Is this only related to the control unit? Or are there other factors involved?
What do you understand by "reasonable values"?
Translated on 18-10-2026, 3:23.
pa-mm6
Post26-06-2007, 20:08    Subject: Golf TDI: When was the emissions light installed? Quote
HI.
It's not showing up under "Exhaust Gas Recirculation" (EGR) in VAG Com 7... and otherwise, nothing useful appears in the OBD measurement block.
Audi SQ5 8R Cvub
Translated on 18-10-2026, 3:24.
Ross-Tech-Support
Post26-06-2007, 23:42    Subject: Golf TDI: When was the emissions light installed? Quote
If the control unit doesn't provide the data, the VC (Vehicle Computer) can't display anything either. Today, I also had a 2006 A6 that did NOT support OBD-2/EOBD. icon_wink.gif
No new posts 1.9 TDI 2V / 2.0 TDI 2V Exhaust Emission Warning Light P0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AWX and ASZ: What are the differences? When to install? Diesel Engine Technology
No new posts Golf IV Cabrio (1E) - Exhaust emissions warning light Gasoline Engine Technology
No new posts LMM Correction: What Happened? Diesel Engine Technology
No new posts Exhaust Light: What It Means & How to Fix On-Board Diagnostics (OBD)
