N75 Valve Test: How to Check While Running
Post26-02-2004, 19:57    Subject: N75 Valve Test: How to Check While Running Quote
Hi.
In the actuator diagnosis process, the N75 valve appears after the N109 valve.
How can I then test the N75 with the engine running, if previously the vehicle is always shut down via the N109 icon_evil.gif?
Translated on 22-09-2026, 11:48.
PowerSound3L
Post26-02-2004, 20:38    Subject: N75 Valve Test: How to Check While Running Quote
hello,
Then, my engine makes a brief sputtering sound, but then it continues to run.
greetings
Translated on 22-09-2026, 11:49.
Gremlin
Post26-02-2004, 22:58    Subject: N75 Valve Test: How to Check While Running Quote
No way...
My ALH is turning off and won't restart. It cannot be restarted until the actuator test is completed.
but you can do something else:
Everyone knows the basic settings on channel 000 for checking the fuel injection timing.
are you looking in here: https://community.dieselschrauber.org/en/viewtopic.php?t=3385
CU Gremlin.
Translated on 22-09-2026, 11:50.
Post26-02-2004, 23:25    Subject: N75 Valve Test: How to Check While Running Quote
Yes, I was just browsing some EDC websites.
I also found the basic settings in the other channels, but nothing has changed cyclically (like with the actuator diagnosis).
Or maybe I was just too impatient.
On the other hand, I realized that with the wastegate N75 valve, not much will happen at idle anyway – except perhaps that the valve might stop clicking.
But thank you for the link.
(who is becoming more and more confident with VAGCOM and will eventually walk icon_rolleyes.gif).
Translated on 22-09-2026, 11:51.
kossmann
2016 Audi Q3
Post28-05-2008, 9:29    Subject: N75 Valve Test: How to Check While Running Quote
The selected topic or contribution does not exist.
Can anyone explain this again? After the actuator diagnosis for N109, my 1Z (with wastegate) is also out - I can click as much as I want, but I can't get it to "flutter" like the N75 icon_confused.gif.
Translated on 22-09-2026, 11:52.
Post28-05-2008, 12:45    Subject: N75 Valve Test: How to Check While Running Quote
kossmann wrote:
After the actuator diagnosis of N109, my 1Z (with wastegate) is also deactivated - I can click as much as I want, but I can't get it to "stutter" like the N75 icon_confused.gif
Does it accept throttle input during the actuator diagnosis?
If applicable, try this: Bring the engine up to approximately 3000 rpm, then double-click the N109 and N75 controls while the engine speed is decreasing towards idle.
However, I am skeptical about whether N109 will receive power again during the following actuator test (N75).
Translated on 22-09-2026, 11:53.
chli1976
Post28-05-2008, 21:26    Subject: N75 Valve Test: How to Check While Running Quote
Why not try using MWB11 and the basic settings, which switch approximately every 10 seconds?
Translated on 22-09-2026, 11:54.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-Com: Can't Access MSG with Engine Running? On-Board Diagnostics (OBD)
No new posts Glow plug light illuminates intermittently with engine ru... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Probleme beim auslesen und loggen bei laufendem motor. On-Board Diagnostics (OBD)
No new posts Testing fuel injectors Diesel Engine Technology
