Document, 2.5 l, 6-cylinder / Jerking/Hesitation (Solution)
Post02-05-2002, 14:04    Subject: Document, 2.5 l, 6-cylinder / Jerking/Hesitation Quote
2.5 liters, 6-cylinder. TDI, AKE engine, manual transmission.
Vehicles exhibit slight vibrations between 1,400 and 2,400 RPM.
Cause:
Software update.
Vehicles exhibit a slight hesitation or jerkiness under partial load conditions. This can occur sporadically, and it can happen when the system is cold or warm.
No errors could be detected in the error memory.
Solution:
Read error codes and check measurement data blocks.
If no indications of the issue can be found in the error memory or through the diagnostic data, replace the engine control unit.
Sure, here's the translation:
"Note:"
The software update only applies to vehicles with manual transmissions.
The A6 Allroad is not affected.
Author: Michael II
Ratings - Document, 2.5 l, 6-cylinder / Jerking/Hesitation
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1K1 DPF, BAG to week 35.04, misfire at approximately... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Jerky A6 2.0 TDI PD Diesel Engine Technology
No new posts 1.9 TDI ASZ Misfire: Causes & Fixes Diesel Engine Technology
No new posts AU-AKN Lag: Troubleshooting & Solutions Diesel Engine Technology
No new posts TDI Jerking on Audi A6 C4 1.9 TDI Diesel Engine Technology
