Virtual COM Port
freizeitmanager
Post29-07-2007, 21:37    Subject: Virtual COM Port Quote
I just bought the professional set from the Dieselschrauber Shop.
I'm very satisfied with it; it has already saved me a lot of money in two cases.
Okay, here's the translation:
Now, my question:
I have a cable with a USB connector, and I read that you can create a virtual COM port using a USB cable.
I visited the Ross-Tech website.
I'm just not getting anywhere with it.
Has anyone ever done this before, and can you tell me how it works exactly?
Thank you and best regards.
Dominik.
Ross-Tech-Support
Post29-07-2007, 22:20    Subject: Virtual COM Port Quote
What exactly are you planning to do, or what exactly do you intend to do with it afterwards?
freizeitmanager
Post30-07-2007, 7:15    Subject: Virtual COM Port Quote
hello,
I want to use this cable for another program that only has a COM port.
Dominik
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post30-07-2007, 11:28    Subject: Virtual COM Port Quote
... the VDC Pro software only works with a real COM port, or what are you planning to do?
If you're looking for information about this, you're in the wrong place, because, according to my information, this software is probably not legally available for purchase.
If I'm wrong, I'm sorry.
Sven.
Passat Variant Highline 2,0 TDI 103KW
Ross-Tech-Support
Post30-07-2007, 13:45    Subject: Virtual COM Port Quote
freizeitmanager wrote:
...wants to use the cable for another program that only has a COM port.
Which specific program are you referring to?
freizeitmanager
Post30-07-2007, 22:23    Subject: Virtual COM Port Quote
I want to use this :O for the BD-II ScanMaster DEMO, and if it works, then I'll buy the full version and also try the PCMSCAN Demo.
I'm looking for a software program (that I can legally purchase) that can read data from other brands besides the VAG group, such as Opel. Most of these programs typically require a COM port.
Thank you, best regards, Dominik.
mullemaus
Post30-07-2007, 22:52    Subject: Virtual COM Port Quote
Why don't you ask the manufacturer of this 'tool'? icon_rolleyes.gif They should be able to tell you everything about the program and its usage as a potential customer or user.
Post31-07-2007, 0:20    Subject: Virtual COM Port Quote
OBD-II ScanMaster DEMO
Tip: VAG-COM already supports OBD2...
PCMSCAN requires an ELM chip, so it definitely won't work without one.
Ross-Tech-Support
Post31-07-2007, 0:26    Subject: Virtual COM Port Quote
Rainer K. wrote:
Tip: VAG-COM can already do OBD2...
However, it's not VPW/PWM, which excludes most of the older Opel models.
Okay, there's nothing that can help with that, not even a VCP driver.
freizeitmanager
Post31-07-2007, 7:33    Subject: Virtual COM Port Quote
auf Deutsch:
"Der schnelle braune Fuchs springt über den faulen Hund."
auf Englisch:
"The quick brown fox jumps over the lazy dog."
I can forget about using the cable to read data from Opel vehicles.
or can someone recommend a free software program, or one that isn't too expensive?
that works with Opel.
Dominik
PS. Has anyone ever done this before with the VTPs from the Rosstech website?
Ross-Tech-Support
Post31-07-2007, 15:27    Subject: Virtual COM Port Quote
I might as well forget about using the cable to read Opel vehicles...
Correct.
P.S. Has anyone ever done this before with the VTPs from the Rosstech website
Yes.
freizeitmanager
Post31-07-2007, 22:25    Subject: Virtual COM Port Quote
Okay, first of all.
Is there another option for Opel, and if so, how much would it cost?
How is the VTP (Virtual Trunking Protocol) working? Is there a guide or someone who can explain it to me? I'd still like to try it out.
Dominik
freizeitmanager
Post03-08-2007, 22:42    Subject: Virtual COM Port Quote
Ah, okay, there's a driver available in the download section of the online store!
No new posts Virtual COM port for HEX-USB+CAN/HEX-USB Troubleshooting & Guides
