Engine Revs Briefly on Its Own?
zecke24
Post26-09-2007, 21:13    Subject: Engine Revs Briefly on Its Own? Quote
'I mentioned this problem here some time ago, but unfortunately, the previous posts didn't offer any helpful solutions. I have a Passat TDI with a 130 hp AVF engine.'
Occasionally, the car accelerates on its own while driving. It's only for a very short time, causing the car to briefly accelerate sharply and lurch forward (maybe for about 1 second).
das macht er auch wenn ich mich rollen lasse oder bremse, also bei Schubabschaltung. Ich habe festgestellt, daß dies nur bei bestimmten Drehzahlbereichen (ungefähr lt. Drehzahlmesser) passiert: bei 1600, 2000, 2600 und 3200 U/min. Aber nicht immer. Die Verbrauchsanzeige zeigt in diesem Moment auch einen Verbrauch an so zwischen 0,5 - 1,1 l/100km, wohlgemerkt bei Schubabschaltung, wo ja eigentlich kein Sprit befördert werden dürfte. Der Fehlerspeiche sagt nichts. Hhelp!!!
Best regards, Arne.
Translated on 25-08-2026, 5:52.
Malte1408
Post26-09-2007, 22:39    Subject: Engine Revs Briefly on Its Own? Quote
Okay, I just skimmed the old thread. As you mentioned, you've already replaced the coolant temperature sensor.
I'm afraid this error will only be resolved with a lot of research effort.
Several sources could be causing the error, so the only solution is to log data and hope that an outlier will appear long enough to identify it.
Can you somehow trigger the error?
Translated on 25-08-2026, 5:53.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post27-09-2007, 17:35    Subject: Engine Revs Briefly on Its Own? Quote
"... that sounds so much like the G62 that, if I were you, I would exchange it again..."
It's possible that a new part could be defective, or perhaps there's an issue with the wiring to the G62.
It's better to waste 25 euros than spend forever searching for something.
Sven.
Passat Variant Highline 2,0 TDI 103KW
Translated on 25-08-2026, 5:54.
zecke24
Post27-09-2007, 21:40    Subject: Engine Revs Briefly on Its Own? Quote
I can't reproduce the error on demand. It only occurs when I drive for a long time within the specified RPM ranges. I only have a trial version of VAGcom, and unfortunately, I don't have a laptop to log data while driving. What else can I do?
Best regards, Arne.
Translated on 25-08-2026, 5:55.
makrospex
Post02-10-2007, 16:52    Subject: Engine Revs Briefly on Its Own? Quote
It's possible that the ESP isn't fully recalibrating...
The consumption display also receives its data from the energy management system (EMS)/control unit.
Possibly the point machine is dirty or slightly misaligned.
It's just a guess; I had the same problem with my old Passat sometimes, but it was sold before I could find the cause.
macro
Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
Translated on 25-08-2026, 5:56.
Hati
Post02-10-2007, 17:01    Subject: Engine Revs Briefly on Its Own? Quote
Even if the G62 were defective, it should under no circumstances inject fuel at speeds far above idle and without the accelerator pedal being pressed. My suspicion leans more towards a faulty throttle potentiometer or wiring.
Translated on 25-08-2026, 5:57.
makrospex
Post02-10-2007, 17:09    Subject: Engine Revs Briefly on Its Own? Quote
...which can also be observed using a VAG-COM device or a multimeter.
However, I would choose an analog multimeter in that case, if a VAG-COM diagnostic tool is not available.
macro
Translated on 25-08-2026, 5:58.
Malte1408
Post02-10-2007, 19:15    Subject: Engine Revs Briefly on Its Own? Quote
It's possible that the ESP isn't fully regulating...
The consumption display also receives its data from the ESP/control system.
Possibly, the point machine is dirty or slightly misaligned.
He doesn't have ESP, and he also doesn't have a quantity setting device...
Differences in regulations from the manufacturer's specifications that are so significant that they cause the vehicle to accelerate on its own would almost certainly result in an error message.
Regarding the quantity setting, the EDC is quite precise. Take a look at the tolerance values for the full load/stop setting in document MWB 19...
Translated on 26-09-2026, 21:35.
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine stalls shortly before reaching operating temperature On-Board Diagnostics (OBD)
No new posts TDI 1.9 Engine: Stalling, Surging, or Running Rough? Diesel Engine Technology
No new posts Fuel Injector Start: Automatic Adjustment Diesel Engine Technology
No new posts Does the Sharan brake automatically? Is the ESP system re... On-Board Diagnostics (OBD)
