BKD Engine: Does it have a balance shaft module?
olli
Karma: +46 / -0   Thank you, like it!
Post23-04-2015, 9:36    Subject: BKD Engine: Does it have a balance shaft module? Quote
Being made aware of the current damage to the hexagon of the oil pump drive, I would like to know if the BKD engine installed in a colleague's Touran is also affected.
Best regards from Berlin.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 04-10-2026, 1:59.
Karma: +807 / -0   Thank you, like it!
Post23-04-2015, 9:47    Subject: BKD Engine: Does it have a balance shaft module? Quote
No, the BKD engine does not have an balance shaft module.
However, the chain tensioner, which drives the oil pump from the crankshaft, can fail. icon_wink.gif
However, I'm not sure at what mileage this occurs, or how frequently.
Translated on 04-10-2026, 2:00.
olli
Post23-04-2015, 9:52    Subject: BKD Engine: Does it have a balance shaft module? Quote
Thank you for the information.
Best regards, olli.
A6 CANA/JME /
Ex-A6 AEL
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Balance Shaft Module for 2.0 8V PD Engine Diesel Engine Technology
No new posts Audi A4: Check Timing Chain Module (TCM) Diesel Engine Technology
