VP37: ATDC 17.4° - Power Loss Issue
t3_tdi
Post03-10-2007, 1:15    Subject: VP37: ATDC 17.4° - Power Loss Issue Quote
Hello everyone,
We are having a problem with a 1Z-90PS TDI engine (manufactured in 1996) that is currently installed in a T3 vehicle.
Since a certain point in time, he has experienced a noticeable and sudden loss of performance. According to the VAG-COM diagnostic tool, the injection timing is completely out of sync. However, it cannot be adjusted. Rotating the pump does not result in any changes to the injection timing.
For example, if you log ATDC data while driving, you won't see any changes in the mapping.
The error log indicates that the pump can no longer be adjusted.
When looking at the engine control unit (ECU) data, specifically the injection timing values for each cylinder, these values do not change.
Boost pressure is okay.
MAF ok.
The timing belt, including the timing belt pulley (the front surface of the crankshaft was machined), was replaced using VAG-specific tools.
I suspect there might be something wrong with the pump. However, I haven't found anything about a constant ATDC value so far.
Does anyone have any ideas?
Best regards, Gunnar.
Translated on 19-10-2026, 9:21.
Karma: +807 / -0   Thank you, like it!
Post03-10-2007, 8:52    Subject: VP37: ATDC 17.4° - Power Loss Issue Quote
Okay, then you should check the cable to the solenoid valve of the fuel injector and the valve itself. If the pump is properly adjusted (in the correct position), there's likely an open circuit somewhere.
Translated on 19-10-2026, 9:23.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Injector sizes for TDI engines with distributor injection... Technical Data
No new posts ESP VP37 Diesel Engine Technology
No new posts VP37: efi 715 - Fuel regulation Diesel Engine Technology
No new posts VP37 Nut: Special Nut for VP37 Diesel Engine Technology
No new posts VP37 Set Screws: Installation & Guide Diesel Engine Technology
