Audi A6 Error 01117: Load Signal Fault
knubbi
Post16-09-2007, 6:36    Subject: Audi A6 Error 01117: Load Signal Fault Quote
Hello forum!
I need your help.
I'm currently working on an Audi A6 with a 2.5L TDI AFB engine / Tiptronic transmission. (Manufactured in September 1998, 244,000 km).
Recently, shortly after starting the car, the transmission has been going into limp mode while driving, and the ESP warning light has been turning on.
The diagnostic scan revealed the well-known error code 1117, as well as an error entry in the ABS control unit.
01117 027
Load signal for generator terminal DF.
implausible signal
Error in the ABS control unit (also in the...
Transmission control unit.
18265 035 P1857
Last signal.
Error message from the engine control unit.
I then had the Lima (alternator) rebuilt, but the problem is still the same. The wiring also seems to be fine.
'The interesting thing is that the charging voltage of 14V is present when the engine is running, and that the error itself is logged after a few seconds, even when the engine is not running (only the ignition is switched on).'
Does anyone have any idea what this could be?
I found some threads about this in the forum, but no one actually wrote down what it really was.
I am grateful for any advice.
Knubbi.
P.S.: Just another piece of information: The error occurs exactly 10 minutes after the system is turned on, regardless of whether the engine is started or only the ignition is switched on.
I suspect that the error entry does not represent the actual error.
Translated on 24-09-2026, 0:58.
knubbi
Post24-09-2007, 11:25    Subject: Audi A6 Error 01117: Load Signal Fault Quote
I found the error, thank you for your help.
Knubbi.
Translated on 24-09-2026, 1:00.
mserge
Post24-09-2007, 16:31    Subject: Audi A6 Error 01117: Load Signal Fault Quote
Knubbi
Hello, could you please tell us where the problem was?
Thank you very much.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 24-09-2026, 1:01.
knubbi
Post24-09-2007, 16:32    Subject: Audi A6 Error 01117: Load Signal Fault Quote
The alternator regulator was defective.
Malte1408
Post24-09-2007, 17:16    Subject: Audi A6 Error 01117: Load Signal Fault Quote
and then the transmission goes into emergency mode?
knubbi
Post24-09-2007, 19:21    Subject: Audi A6 Error 01117: Load Signal Fault Quote
Yes, exactly.
Because the motor load signal can no longer be calculated correctly. The lighting machine load is a component in the calculation of the motor load.
Translated on 24-09-2026, 1:02.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post24-09-2007, 22:41    Subject: Audi A6 Error 01117: Load Signal Fault Quote
knubbi wrote:
Yes, exactly.
Because the motor load signal can no longer be calculated correctly. The lighting machine load is a part of the motor load calculation.
I then had the Lima rebuilt - but the same error persisted. The wiring also seems to be okay.
And what did you have serviced at LIMA?
That load signal issue is quite something. In this case, the solution was even stored in the error memory.
implausible signal
B.Eng (FH) u. KFZ Meister
Translated on 24-09-2026, 1:03.
knubbi
Post25-09-2007, 13:29    Subject: Audi A6 Error 01117: Load Signal Fault Quote
I simply replaced the regulator. Before that, I ran the machine on a Lima test bench here at our company. The regulator itself was working perfectly. However, that has nothing to do with the function of the DF terminal.
Translated on 24-09-2026, 1:04.
Post25-09-2007, 14:45    Subject: Audi A6 Error 01117: Load Signal Fault Quote
I also used to get the "DF" error message in my Golf from time to time.
I couldn't detect any effects whatsoever...
knubbi
Post25-09-2007, 16:25    Subject: Audi A6 Error 01117: Load Signal Fault Quote
In my case, it was obvious. When two lights come on in the cockpit and the transmission only engages up to the 4th gear, then you can definitely talk about noticeable effects.
Translated on 24-09-2026, 1:05.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post25-09-2007, 16:43    Subject: Audi A6 Error 01117: Load Signal Fault Quote
dieselmartin wrote:
I also used to get the DF error from time to time in my Golf.
The load signal only affected the automatic transmission.
For comfort reasons, the brake couplings will be controlled more gently in the partial load range.
For example, in the case of a V8 engine, the load signal comes from the engine control unit (ECU) via the mass airflow sensors.
If these components fail, the transmission can very quickly become damaged.
Malte1408
Post25-09-2007, 17:55    Subject: Audi A6 Error 01117: Load Signal Fault Quote
For example, in a V8 engine, the load signal comes from the engine control unit (ECU) via the mass airflow sensors.
Yes, but what makes me wonder is why the "clamp-DF" signal is so important for load calculation in a TDI system.
He is quality-controlled, and the engine control unit (ECU) knows the injectionmass (and not, as with a gasoline engine, some arbitrary time) and the speed. What more could one want for an accurate load calculation?
He probably wants to calculate the torque transmitted directly to the transmission, but for that, he would also need to factor in the air conditioning and power steering.
Translated on 24-09-2026, 1:07.
knubbi
Post28-09-2007, 11:49    Subject: Audi A6 Error 01117: Load Signal Fault Quote
Now you've answered the question yourself...
Translated on 24-09-2026, 1:08.
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 17911 - Load signal from generator terminal DF On-Board Diagnostics (OBD)
No new posts Engine won't shut off - Load signal for generator terminal On-Board Diagnostics (OBD)
No new posts EDS System Error: Troubleshooting & Fixes Diesel Engine Technology
No new posts Audi A3 CFGB: AGR Fault & Fix Diesel Engine Technology
