dagegen
Joined: 07/22/2007 Posts: 20 Karma: +0 / -0 Location: Kreis Schleswig-Flensburg
29-10-2007, 12:20 Subject: VW Passat: ESP Light On - What to Do? |
Hello, after a period of calm since my first problem here ("VW Passat switches to limp mode at 180 km/h"), I'm experiencing a new issue since last night:
After 600 km of flawless driving, the car suddenly started to jerk in the city. First gently, then increasingly strongly. The driver applied the accelerator as usual at all times, but it felt like he was constantly being hit from below. It's difficult to describe. After releasing the clutch, the car rolled normally. Additionally, the ESP warning light came on.
Is this another one of those electronic problems, or could it be something mechanically broken? The car is currently in front of my door, and I don't know what to do with it – whether I can still drive it to the workshop, etc. Maybe I should have bought that diagnostic kit after all...
Translated on 21-10-2026, 12:55.
matthiasTDI96 Profi-Schrauber
29-10-2007, 13:28 Subject: VW Passat: ESP Light On - What to Do? |
Okay, now VAG-COM would be very helpful. If it's the ESP light, I'm initially suspecting a sensor problem (given the long journey). Perhaps a wheel sensor is faulty, a connector is wet, or a cable is broken. What kind of "jolts" are we talking about? Does it sound like the ABS/ESP pump? Is there a brake intervention involved?
Translated on 21-10-2026, 12:56.
dagegen
29-10-2007, 16:46 Subject: VW Passat: ESP Light On - What to Do? |
It feels like the car isn't accelerating properly and it's bouncing. However, when you press the gas pedal, it does accelerate normally, but the bouncing becomes more pronounced.
Is it possible that the ESP system is simply braking individual wheels, which is causing the bouncing effect?
What do you mean by "brake intervention"? About 3 weeks ago, the brake discs and pads were replaced on the rear.
Translated on 21-10-2026, 12:57.
dagegen
01-11-2007, 19:14 Subject: VW Passat: ESP Light On - What to Do? |
The error code indicated that cylinder 1 was no longer functioning.
So, you have two options: either cables (approximately 150 euros) or a pump-injector unit (approximately 600 euros).
Let's see.
Translated on 21-10-2026, 12:58.
boradh
Joined: 11/12/2007 Posts: 5 Karma: +0 / -0 Location: 49356
12-11-2007, 22:57 Subject: VW Passat: ESP Light On - What to Do? |
Hey!
"The error code indicated that cylinder 1 was no longer functioning."
Is this roughly what you're looking for?
18074 - Valve for Pump-Jet: Cylinder 1 (N240): Electrical Malfunction.
P1666 - 35-10 - - - Intermittent.
So, there's an electrical malfunction... what did you do?
Translated on 21-10-2026, 12:59.
dagegen
12-11-2007, 23:21 Subject: VW Passat: ESP Light On - What to Do? |
VW hat den Kabelbaum getauscht, Kostenpunkt ca. 160 Euro incl. Wage.
No problems since then.
13-11-2007, 7:09 Subject: VW Passat: ESP Light On - What to Do? |
dagegen wrote: | VW hat den Kabelbaum getauscht, Kostenpunkt ca. 160 Euro incl. Wage.
Since then, there have been no more problems. |
Okay  I assume it was the PDE wiring harness? Gruß Ulf
Translated on 21-10-2026, 13:00.
Profile PM Garage |
dagegen
13-11-2007, 21:50 Subject: VW Passat: ESP Light On - What to Do? |
"Pump nozzle control unit" is listed on the invoice.
What about engine oil, actually?
What is the difference between 5W-40 oil with the VW 50501 specification and 5W-40 oil without this specification?
14-11-2007, 7:29 Subject: VW Passat: ESP Light On - What to Do? |
dagegen wrote: | | What distinguishes 5W-40 oil with the VW 505.01 specification from 5W-40 oil without this designation? | Primarily, it's the specific additives that ensure the survival of the TDI engine despite its extreme surface pressures. Gruß Ulf
Translated on 21-10-2026, 13:01.
Profile PM Garage |
