Moment of inertia of the drive shaft
Martin L.
Post17-04-2002, 14:04    Subject: Moment of inertia of the drive shaft Quote
Does anyone have values for the moment of inertia of the entire powertrain? Even approximate values would be helpful. For example, depending on the engine displacement and drive type (front-wheel drive, rear-wheel drive, and all-wheel drive).
Unit: [kg m²]
'Thank you very much!!'
Martin.
