50700 Oil: Specs, Brands & Buying Guide
Go to page: 1, 2  Next
Post24-10-2007, 10:49    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Hi.
I've stocked up on 20 liters of Castrol oil. It's probably a mineral-based (HC) oil and it's really expensive.
My brother-in-law managed to find "Ravenol." It's a fully synthetic oil with the specification 50700, and it's surprisingly cheap at 47 euros for 5 liters.
Does anyone else know about the 50700 and its characteristics?
Translated on 25-08-2026, 0:03.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post24-10-2007, 12:04    Subject: Pennasol LL3: 50700 WIV Product Details Quote
I'm not trying to get rid of my oils here, and if anyone is interested, please contact me via private message.
However, in addition to Ravenol, I also distribute Pennasol (from the Dollbergen refinery).
However, it meets the VAG standard 50 700 icon_wink.gif and is a full synthetic 5W oil.
In terms of price, it's in a similar range - you save the most on shipping costs when ordering 4 x 5-liter containers. icon_idea.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 25-08-2026, 0:05.
haithamina
Post24-10-2007, 13:57    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
I recently discovered Ravenol as well. By the way, it's a 5W-30 oil; just adding that as extra information.
Otherwise:
Mobil 1 ESP Formula 5W-30, High Mileage.
Valvoline - SYNPOWER XL - III, SAE 5W-30, Fully Synthetic.
High Performance 5W-30 VW Longlife 3, HC.
Liqui Moly TOP TEC 4200 SAE 5W-30, HC.
megol Compatible 5W-30, HC
Transit Diplomat Longlife III 5W-30, HC.
ELS® Premium LongLife III, 5W-30, supposedly fully synthetic.
Addinol Mega Light MV 0539 LE, SAE 5W-30, HC.
haithamina
Translated on 25-08-2026, 0:07.
BM
Avatar-BM
Post24-10-2007, 14:08    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Now my brother-in-law has found "Ravenol"
My car has been running on Ravenol for almost 200,000 kilometers with very minimal oil consumption.
3B5 AJM
Translated on 25-08-2026, 0:09.
mserge
Post24-10-2007, 15:14    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
I'm using Gulf Formula GVX 5W-30 oil in my PD diesel engine. It meets the VW 507.00 specification. I don't remember the exact price, but it was under €15 per liter in a 5-liter canister.
My V6 engine has been switched to 15,000-mile service intervals and receives either 5W-40 synthetic oil or 10W-40 conventional oil, depending on what I have in stock at the moment.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 25-08-2026, 0:10.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post24-10-2007, 17:20    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
BM wrote:
My car has been running on Ravenol for almost 200,000 km with very little oil consumption.
I switched both my own vehicle and the company fleet to Ravenol oil (10W-40) due to its lower oil consumption.
Thomas K.
Post25-10-2007, 12:53    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
By the way, all 'Longlife III' oils, meaning those meeting the specifications 507.00/504.00, are actually HC (hydrocarbon) oils and not fully synthetic. This is also stated on Ravenol's website.
Translated on 25-08-2026, 0:11.
Post25-10-2007, 13:26    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
That's not true.
This is FULLY SYNTHETIC.
http://www.ravenol.de/products?part=323
http://www.ravenol.de/idata/popups/323.jpg
Translated on 25-08-2026, 0:12.
pschaefer
Post25-10-2007, 13:47    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Hmm... That would be a first of its kind!
But even here: http://www.ravenol.de/products?part=362 the packaging says "Fully Synthetic", but it is listed under "Hydrocracked"...
Peter.
Thomas K.
Post25-10-2007, 14:51    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
You're all kind of right, but we're talking about the 507.00, meaning this one here.
http://www.ravenol.de/products?part=342
and it just says 'synthetic' and not 'full synthetic.'
However, there really isn't a fully synthetic 507.00/504.00 icon_cool.gif.
Translated on 25-08-2026, 0:13.
Post25-10-2007, 16:05    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
If you look at the two posts above this one, you will see two links.
If you click on it, you'll see fully synthetic 50700 oil!
Translated on 25-08-2026, 0:14.
Thomas K.
Post25-10-2007, 17:21    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Only the Ravenol HLS meets the VW standard 507.00/505.00, and it is labeled as synthetic and is an HC oil.
I can only reiterate that there is definitely no 507.00/504.00 fully synthetic oil. These are all HC oils, which are often referred to as synthetic or using synthetic technology. However, modern HC oils can sometimes be 'better' or more advanced than traditional full synthetic oils.
Translated on 25-08-2026, 0:15.
BM
Avatar-BM
Post25-10-2007, 18:26    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Only the Ravenol HLS has the VW standard 507.00/505.00, and it is labeled as synthetic and is a hydrocarbon (HC) oil.
And what about this one: http://www.ravenol.de/idata/popups/323.jpg icon_question.gif
It also has the specifications 54 00 and 57 00, and is listed as being fully synthetic.
3B5 AJM
Translated on 25-08-2026, 0:16.
Thomas K.
Post26-10-2007, 8:54    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
...okay.
'However, this oil is missing a description of its properties and standards on the webpage. Furthermore, there are some inconsistencies in the information provided on the page. The HLS is listed as an HC product, but the canister also indicates that it is fully synthetic...'
There was a lawsuit filed by Mobil claiming that the term 'fully synthetic' could only be used on packaging if the oil inside was truly fully synthetic. However, they were only successful in Germany; therefore, it is permissible to use this term on packaging in other EU countries.
Again, Longlife III means HC oil, regardless of what they write on the page.
Translated on 25-08-2026, 0:17.
Post26-10-2007, 9:31    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
Again, Longlife III = HC oil, no matter what they write on the page.
Okay, but they are attributing it to the *product* that they are selling in Germany.
So, it's either a violation of the terms of service or a breach of law.
Translated on 25-08-2026, 0:18.
Post26-10-2007, 9:37    Subject: 50700 Oil: Specs, Brands & Buying Guide Quote
We could always check.
Ravensberger Lubricants Distribution GmbH.
Jöllenbecker Straße 2, 33824 Werther.
(0 52 03) 97 19-0
Fax: (0 52 03) 97 19-40
Fax: (0 52 03) 97 19-41
Translated on 25-08-2026, 0:19.
