TDI Coolant Temp Sensor for Audi Convertible
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
TDI-Schorsch
Post18-10-2007, 19:59    Subject: TDI Coolant Temp Sensor for Audi Convertible Quote
Here are the log files for the intake air temperature.
LOG-01-007-008-010.CSV
 File name:  LOG-01-007-008-010.CSV
 File size:  43.41 KB
 Downloaded:  792 times
LOG-01-003-007-011.CSV
 File name:  LOG-01-003-007-011.CSV
 File size:  44.11 KB
 Downloaded:  810 times
Translated on 27-07-2026, 2:37.
Post18-10-2007, 20:12    Subject: TDI Coolant Temp Sensor for Audi Convertible Quote
You can pretty much forget about the 7-8-10 log because you didn't even go full throttle.
You can only get a vague idea of LLT problems when riding in a car.
It should include at least one full-throttle acceleration from 1300 to 4500 rpm in 3rd gear or higher.
Furthermore, the outdoor temperature is not specified.
Translated on 27-07-2026, 2:38.
Post18-10-2007, 20:24    Subject: TDI Coolant Temp Sensor for Audi Convertible Quote
If it's not actually below freezing, I don't see an urgent need to take any action. Perhaps you could try rinsing the radiator fins from the back with a garden hose to remove dirt. Be careful not to use too much pressure (like a pressure washer), as that can bend the fins.
 File size:  68.53 KB
 Viewed:  1126 times
Translated on 27-07-2026, 2:39.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Cabrio hidden control unit On-Board Diagnostics (OBD)
New posts Audi A5 Convertible Seat Memory Retrofit Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI Intercooler Upgrade for Audi Cabrio MKB:AHU On-Board Diagnostics (OBD)
No new posts Audi Cabrio 89: Convertible Top Control Unit Not Responding On-Board Diagnostics (OBD)
