Dry run --> Engine control unit malfunction
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
RĂŒdi
Karma: +640 / -0   Thank you, like it!
Post02-01-2008, 20:08    Subject: Dry run --> Engine control unit malfunction Quote
Today, my LG (presumably a car) broke down with the Passat 3B from the signature below, and I drove it safely.
She called me at work, I rushed over, and I happened to have a borrowed 1551 with me.
I'm going to quickly read the error codes, there were stored:
Faulty Engine Control Unit
Error fixed, won't happen again but car won't start, towed home, refueled, air filter bled, got into a crisis, while working on the fuel injector bled, started and ran, then replaced the diesel filter, test drive, runs perfectly.
"No errors detected" is now at line 1551
Do I have a brain injury or what's going on?
Please help me.
Best regards, RĂŒdi
Post06-01-2008, 3:36    Subject: Dry run --> Engine control unit malfunction Quote
I've had this kind of error a couple of times in the 1Z, I've deleted it, but it keeps coming back occasionally. The engine is running normally (no limp mode or rough running). I'm not sure where this error is coming from! As long as the box is running perfectly, I have no reason to doubt it.
No new posts Doku, n.löschb. Fehler im MotorsteuergerÀt 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MotorsteuergerÀt defekt!? On-Board Diagnostics (OBD)
No new posts MotorsteuergerÀt defekt oder was anderes? On-Board Diagnostics (OBD)
No new posts MotorsteuergerÀt defekt, bin auf der Suche nach Ersatzge... On-Board Diagnostics (OBD)
No new posts MotorsteuergerÀt 600 km nach Austausch Injektoren defekt On-Board Diagnostics (OBD)
