Leadership shortage and increased consumption of AFN, please check logs.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Upload
powmia
Karma: +5 / -12   Thank you, like it!
Post14-01-2008, 16:19    Subject: Leadership shortage and increased consumption of AFN, please check logs. Quote
hi,
Please find the logs from the data blocks 000 007 010 and 000 008 011 attached. Please take a look at them.
During two of the test runs, it went into limp mode at 165 km/h, due to a difference in engine regulation, specifically the intake manifold pressure (00575).
Need your help =((
Best regards, Pierre
File_000_008_011.xls
 File name:  File_000_008_011.xls
 File size:  38.5 KB
 Downloaded:  408 times
File_000_007_010.xls
 File name:  File_000_007_010.xls
 File size:  87.5 KB
 Downloaded:  410 times
No new posts Prüfen des Hallgebers von Zündanlagen Troubleshooting & Guides
No new posts TDI 1.9L Injection Pump: Testing & Adjustment Troubleshooting & Guides
No new posts Vibrationen und Mehrverbrauch ASZ Logs Upload
No new posts P0299: Limit exceeded, please comment on logs Diesel Engine Technology
No new posts Temp. Advertisement, Check ?? Diesel Engine Technology
No new posts Testing and Adjustment of the TDI 1.9L Distributor Inject... Diesel Engine Technology
