TDI Turbocharger: 96kW Models
Raoul
Post18-07-2002, 19:18    Subject: TDI Turbocharger: 96kW Models Quote
Hello!
Which turbocharger is used in the TDI PD 96kW engine (manufacturer and model number)?
Raoul.
Translated on 25-07-2026, 17:41.
Special TDI
Post24-12-2002, 1:59    Subject: TDI Turbocharger: 96kW Models Quote
Hello Raoul,
In the 1.9 TDI PD engine with MKB: ASZ and a production date of November 2002, a Garrett turbocharger is installed, specifically the GT17 49V turbocharger, which is the same as used in the 110 kW ARL TDI engines; I have compared the specifications. icon_exclaim.gif
I hope I can help you with that.
Patrick.
Translated on 25-07-2026, 17:42.
Stefan
Post24-12-2002, 8:38    Subject: TDI Turbocharger: 96kW Models Quote
What is the actual boost pressure of a standard 1.9L 150hp common rail engine?
Michael748
Post24-12-2002, 11:07    Subject: TDI Turbocharger: 96kW Models Quote
1.5 bar
By the way, I don't think the 150 hp version has the same turbocharger as the 130 hp version (which uses a 1.3 bar boost pressure).
The difference in maximum boost pressure is quite significant.
Translated on 25-07-2026, 17:43.
Manuel Thomas
Post28-12-2002, 20:06    Subject: TDI Turbocharger: 96kW Models Quote
The 150 hp PD-TDI engine is equipped with a Garrett VNT 20 turbocharger.
Manuel.
Translated on 25-07-2026, 17:44.
plexi32
Post28-12-2002, 22:09    Subject: TDI Turbocharger: 96kW Models Quote
The 150hp PD-TDI engine features a Garrett VNT 20.
And which one is for the ASZ (96kW)? Is it true that a GT17 49V turbocharger is used?
Manuel Thomas
Post28-12-2002, 22:50    Subject: TDI Turbocharger: 96kW Models Quote
I only know the designation Garett VNT 17.
It will probably be the same.
Manuel.
Translated on 25-07-2026, 17:45.
GOLFTDI
Post29-12-2002, 13:47    Subject: TDI Turbocharger: 96kW Models Quote
According to the original Volkswagen repair documentation, both the 130 hp and 150 hp TDI engines use the same turbocharger: a Garrett GT17 49V.
Raoul
Post29-12-2002, 14:38    Subject: TDI Turbocharger: 96kW Models Quote
Hello!
Thank you for the information!
What is the boost pressure at which the GT17 turbocharger operates?
Here's another page with performance charts. http://www.egarrett.com/products/gt_15_25.jsp I'm not quite sure what to make of it.
Raoul.
Translated on 25-07-2026, 17:46.
Manuel Thomas
Post29-12-2002, 15:34    Subject: TDI Turbocharger: 96kW Models Quote
It's funny that the image shown for your link is a turbocharger with a wastegate.
I'm not familiar with the designation 'GT'; I always thought they were called 'VNT.'
Where can I find information and data about the chargers in German?
The thing about the repair manuals is interesting. A friend of mine has a Leon with a 150hp TDI engine, and the designation includes a '20' somewhere.
Manuel.
Translated on 25-07-2026, 17:47.
GOLFTDI
Post29-12-2002, 16:25    Subject: TDI Turbocharger: 96kW Models Quote
I believe the GT 17 49 can deliver a maximum pressure of up to 1.8 bar!
It's typically operated at 1.5 bar in the 150 series and at 1.3 bar in the 130 series.
Translated on 25-07-2026, 17:48.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts Power loss issue, 96kW PD-TDI (ASZ) #2 Upload
No new posts Throttle body 96kW PD Diesel Engine Technology
No new posts Leistungsverlust am A3 96kw TDI Diesel Engine Technology
No new posts Power shortage ASZ 96kw Upload
